Porting
Grinder-$50
Bits=$25
Flap wheels $35
WD40
Gloves
Paint
Gaskets:$70
I have done three of them..mine, Katerdons, and CCMANOs
LGAFF
92 #234
90 #966
)I spent a LOT more on bits (I may never use again) until I finally got put onto the SE6. No more welding.
Something else...I'm actually having fun doing it! That I didn't expect, but each "hole" is that much closer to some serious fun.
As for the chip, my Marc H chip was $475 with all "the goodies" in it:
fans (plural) come on at around 200ºF
the high idle is addressed
no backfire with headers
Secondaries on alla time (above 1% throttle)
spark advanced for premium fuel
spark knock re-calibrated
calibrated to run best at higher temp (than stock)
fuel for 55 or so more hp. (top-end (sans heads) porting w/ headers tune)
P.
I have quotes from all the big guys with re sized gaskets Fresh calibration
ect. There is a much bigger difference in price then I had thought. Yes you do get what you pay for.
I have a set of the NOS Injectors would be a good time to do those as well. Crazy thing is car is fine now as far as power, Holds its own against cars costing much more.
I would think Pete would give you the best bang for the cash.
LGAFF
90 #966
92 #234
headers
no cats
X-Pipe
I have yet to get it tuned.
Video of the dyno run on you tube and has been posted here.
http://www.youtube.com/watch?v=8Y4Re5TqIw4
LGAFF
90 #966
92 #234
On a 91 with porting to the Plenum, Injector housings and head match porting about 25hp to the rear. With Longtube headers add another 10hp total in the 35hp min range with more with matching tuning to calibrate for the new mods.
Also another pitch for Jeffvette he offers about 20 different powdercoating painting options colors/flavors if you looking for something different. PM him on the registry if interested.
http://www.zr1specialist.com/HAT%20W...20upgrades.htm
But, back to your question, he says about 30 for the porting alone for a 90-92 engine.
I'm porting the top end, port matching the heads, (porting heads next winter's project, plus cam re-grind), LT headers w/ 3" exhaust, X pipe, adding a chip. Mark has some dyno graphs with pretty much the same setup showing the power curve flattening out (vs. rolling off) above 6000 and remaining practically level to 7000.
All that said, Mark also said the biggest pop for the money is going with a 4.11 gear. It adds another 17% torque in every gear and makes 6th usable at normal highway speeds. (Why not both???
)Skooze me. I hear my die grinder callin' again!
P.
But...the actual porting isn't a DIY job to experiment with. My son tried it and he is an experienced engine machinist with plenty of experience on other cars. I ended up sending my stuff to Corey Henderson who did a great job, then up to Jeff for powdercoating. Locobob helped me put stuff back together.
You might look at doing a CCT replacement at the same time. They are expensive little buggers, but they do wear out and need replacement eventually. If you can still get them (?).
Here is a dyno graph of my 368: before with moderate porting and after with an agressive B port siamese job. As you can see the motor lost around 10ftlbs in the mid range but picked up substantial power above 6K rpms.
best bang for the buck, and yes, make sure you do a decent flowing exh and 4.10 gears too, and throw in a short throw shifter of your choice. modest investment, smoking fast car!
