C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
LT5 engine
Old Mar 21, 2009 | 09:01 PM
61LS6's Avatar
61LS6
Default LT5 engine
I just purchased a 90 LT5 engine and trans to be installed in a 63 SWC.
Prior to instillation what should I do to the engine and trans? The engine has 40,000 miles.
Thanks,
Bill
Old Mar 21, 2009 | 09:31 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
Thanks,
Bill
I guess it depends on how long you plan on it not running.
is the car all done and ready to have the motor dropped in?
Old Mar 21, 2009 | 11:10 PM
Andrew's Avatar
Andrew
I don't have any advice. All I can say is WOW! What an ambitious and very cool project!! I'm sure you will get some great answers here and please keep us updated on the project.
Old Mar 21, 2009 | 11:52 PM
1985 Corvette's Avatar
1985 Corvette
Sounds like an awesome project and one that will drop a lot of jaws when you pop the hood. I'm still waiting for someone to put an LT5 in a C4 vert.
Old Mar 22, 2009 | 01:34 AM
Rkreigh's Avatar
Rkreigh
pull the plugs and spray some light penatrating oil like wd40 down into the cyl and turn the engine over by hand
make sure everything turns over freely. you'll need an oil cooler, and I'd check all the vacuum lines and make sure the secondary actuators work ok by testing with a vacuum pump. go ahead and replace the injectors. the 90s break down with the alchy in the gas and you'll be doing it sooner or later. fic has some really good deals, do a search.
40k miles is low miles on an lt5. keep us posted and have fun!
Old Mar 22, 2009 | 08:14 PM
61LS6's Avatar
61LS6
Default Lt5
I expect to have the engine and car complete in one year from now. I know there will be some chalenges during the journey but that is what makes these projects just plain fun and rewarding when complete.
Thanks, Bill
Old Mar 23, 2009 | 03:51 PM
4DSZR1's Avatar
4DSZR1
Thanks, Bill
Sounds like a very cool project, please, keep us posted and you know we love pictures!!!!
Old Mar 25, 2009 | 09:58 AM
hihok9's Avatar
hihok9
Default Wild ride!
Bill,
This board is a wealth of information that you will probably need. Stock or aftermarket chassis?
Hiho
Old Mar 25, 2009 | 10:17 AM
LT5corsa's Avatar
LT5corsa
1994 Admiral Blue ZZZZZR1
Northeast Events Coordinator
Originally Posted by hihok9
Bill,
Hiho
Hmmmmmmmm
How about an update with pictures and info? Haven't heard anything of that beautiful 66 you have been building.
Old Mar 25, 2009 | 12:55 PM
61LS6's Avatar
61LS6
Default LT5 engine
I am using a Street Shop Chassis
Will keep you posted
Bill
Old Mar 25, 2009 | 01:29 PM
WydGlydJim's Avatar
WydGlydJim
The LT-5 can make a crazy/beautiful streetrod engine....just not done very much for obvious reasons. Good luck on the build! Here is a pic of an LT-5 in a 48 chevy pick-up that was very nicely done!
Old Mar 25, 2009 | 05:38 PM
hihok9's Avatar
hihok9
Default Lt5
Hey Dave!
All my body work is done. Car home in primer so that I could fab the cooling & exhaust before paint. It will be going back to the shop & put on a dolly for paint so that I can bring the chassis home for disassembly and powdercoating.
To LT5 engine
