C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
ignition module?
Old May 12, 2009 | 10:40 AM
99magneticred's Avatar
99magneticred
Default ignition module?
Is the ignition module the same on the 90 zr1s and l98s?
Dealer said it needs tobe replaced, to fix a tacometer problem, and I just want to make sure they put the right one in.
Old May 12, 2009 | 11:17 AM
VetteMed's Avatar
VetteMed
Completely different ignition system. The modules are different. L98 uses a distributor, and the module is mounted there. No distributor in the LT5.
Old May 12, 2009 | 12:08 PM
99magneticred
Do you know how much an lt5 ignition module goes for?
Just trying to dictate by price if they are installing the right one
Old May 12, 2009 | 12:40 PM
VetteMed's Avatar
VetteMed
Dunno, but I've seen them on ebay for big bucks ($500-ish? maybe)
Old May 12, 2009 | 01:41 PM
gbrtng's Avatar
gbrtng
Have the dealer break out the factory service manual and use the troubleshooting guide before they start throwing parts at it. The part is called direct ignition system module. page 8A-22-9 in my 91 FSM.
Old May 12, 2009 | 02:01 PM
99magneticred
well its 400 installed
if it doesnt fix my problem, then I wont be paying, I wont be playing the troubleshoot with the customers money
Old May 12, 2009 | 06:46 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
The ignition modul screwing up the tach?
Im not sure they know what the hell they are talking about.
I sell used ignition modules for $400, a new one is $800 so I do not know what they are installing on your car thats $400 installed??
Old May 12, 2009 | 07:46 PM
99magneticred
I mean i have not dealt with this dealership before, they are a big chevy dealer in the area.
I called to double check they know they are working with an LT5 and they said yeah, their corvette tech, has been working on vettes for 40 years and he is sure he has the right part.
What is my liability if the dealer installs the wrong part, or the part they install does not fix the issue?
Old May 12, 2009 | 07:48 PM
99magneticred
Default yes
yes they said the ignition module, as well as controlling spart plug when they fire etc, that is also relays information regarding revolutions, which goes to the tach.
When they first said it, i was like is it the tach filter?
And they go no its the ignition module.
Old May 12, 2009 | 08:07 PM
WVZR-1's Avatar
WVZR-1
Is your tach "erratic" or just doesn't work?
A '90 tach is notorious for "incremental" error. In '03 mine was maybe 10% high most of the time, in '06 it was maybe 20% high, it's become very erratic this year and I'm quite confident it's related to the cluster circuitry. I've had conversations with a fellow who does tach calibrations for most of the Corvette "mail order" vendors and he feels the same and has pretty much ID'd the capacitors that control it. Maybe this winter I'll let him have "at it"!
If yours is just erratic and very high I'd get the cluster repaired. There are independent vendors for the repairs and the dealership where your car is should be able to do and "advance exchange" or arrange for a repair of yours. It should be accompanied with a 12 month warranty when done.
I could do this with mine also but I'd like to give the fellow a go at it and if it's a confirmed "fix" it will be something to pass-on.
If you've "NO TACH SIGNAL" yes it's a possible diagnosis!
Where are you located? I'd be interested to speak to you!!
You can likely "confirm" what I've mentioned and "shorten" the diagnostics! Using a Tech1 or similar diagnostic device attach it to the ALDL and if you've got a "CORRECT and CONSISTENT" tach value you've "confirmed" I'm quite sure what I've mentioned. Mine has been confirmed with my Tech1 and also Diacom. All you need to compare is RPM's to MPH! I would have thought this was a first step in diagnostics at a "dealership" level! Again if you've "NO SIGNAL" anywhere maybe they're good with the diagnostics!!
Old May 12, 2009 | 08:17 PM
99magneticred
I am located in indiana.
Mine is not eratic, it just flat doesnt work.
They said the guage was fine and supposly tested it, and this is what he came too.
I thought 400 installed for the module was cheap related to what i see on here, expensive to me, to just get a tach repaired though
I guess i will let them try, and will report back in the next day or two.
Old May 12, 2009 | 08:24 PM
WVZR-1's Avatar
WVZR-1
See my last "edit" in the post previous to this!!
Old May 12, 2009 | 08:26 PM
-=Jeff=-'s Avatar
-=Jeff=-
Well if they fit the L98 Module on the LT5 I will be amazed..
L98 Ignition module is smaller then a pack of cigarettes..
the LT 5 Ignition module is about 1/2" thick and roughly 4.5" x 6.5"
I think the Tach not working is either:
-Bad wire to Cluster
-Bad Cluster
-Bad tach filter ( if the LT5 even has one)
lastly it could be the IM but I am doubting it
Old May 12, 2009 | 08:44 PM
WVZR-1's Avatar
WVZR-1
The diagnostics appear pretty straight forward and I'd only suggest the check at the ALDL for a "tach signal" and if it appears to be consistent and correct for the approriate speed while driving with the Tech1 or "whatever" attatched. I've only ever seen the "cluster/tach" tester they mention in the FSM a couple times and not in the past 10-12 years for sure!
I mention mine being "very erratic" this year and yes from time to time it's "completely dead"!!
Old May 12, 2009 | 11:44 PM
secondchance's Avatar
secondchance
Run a search on "fleabay" for LT5 ignition module. There is one listed for $550. Also, to install, plenum has to be pulled. I figure 2 hrs, maybe?
I can't imagine Chevy dealer voluntarily giving you deep discount on part and installing it at cut rate.
I would check and make sure that it is indeed the "ignition module". If so, that they are pricing a correct one.
I just ran a search for 1990 Corvette ignition module on gmpartsdirect.com and only one showing up is for 84-91 for $67. This is obviously for L98 and one for LT5 doesn't even show.
Old May 13, 2009 | 09:37 AM
Dominic Sorresso's Avatar
Dominic Sorresso
I'll buy the one they pull out. PM me.
Old May 13, 2009 | 10:52 AM
secondchance
Well, I may have jumped the gun.
I talked to parts department at P&G Chevrolet and according to Bill module shown on the exploded view, #526, is listed as below.
Part No. Description LIST YOURS
19179581 module $47.77
attached is the illustration I quoted item # 526
http://s658.photobucket.com/albums/uu303/byongyun/
And the part is still available. Only question is is this realy the ignition module? Bill wasn't sure.
To ignition module?
Old May 13, 2009 | 11:00 AM
Dominic Sorresso
That's the right part according to the illustration. I'll take 10 of them for that price. I have a spare one and the PN for it 1103841. That's on the module itself. I'm incredibly skeptical.
Old May 13, 2009 | 11:09 AM
secondchance
Talk to Bill at P&G Chevrolet. I think his last name is Marko. Outstanding service.
888 870 0280 x 214
Old May 14, 2009 | 01:34 PM
phrogs's Avatar
phrogs
the part number they gave you a p&G is jacked
The ignition module part number is 1103841
and its NLA from GM
the other part number is wrong
Id have the dealer that quoted that price order one and have them order it and if its the correct one Id buy it if not its there part because the computer is wrong.
