Cruise Control quit working
The cruise control on my 91 Z has quit working. I've had the car 3 years and it has 23k miles. The cruise worked until last summer. I checked the fuse panel, where should I look next? What is the common failure?
Thanks,
Randy
Thanks,
Randy
It's commonly a flaw in the vaccum system, leading to or from the cruise servo which is located above the battery. The vacuum line should be checked for cuts or chafing, including under the dash where the hose connects to the brake switch.
Mine on the 90 quite working a few years back.... turned out to be the speedo gear in the trans. That could be the first sign of the grear going south, then the speedo works intermitently and the car might even stall when you stop... the first sign was the cruise. Good Luck!
Been working around the pedals? Check the brake switches that they are centered on the full area above travel of the pedal arm. If they are off centered the cruise wont engage. Also if either of these switches are not working. GC
I did have to replace the brake switch last year. I don't know if that's when it quit because I don't use the cruise unless we're on an interstate trip. What do you mean by "off centered"?
It (the switch) needs to be centered on the pedal arm. If its offset it wont make contact with the switch and the cruise will not set.
Thanks again,
Randy
