zr1 boost
2nd Gear
zr1 boost
Hi i am new to all this computer stuff,But i wonder if anyone can help me i have a 1990 corvette zr1,which has the second key for the ful power of the engine,this i cannot get to work at the prsent time i have had a few people look at it but to no avail what i need is someone to give me some idea of what the problem could be can anyone help me please i live in the uk so not a lot of corvettte experts here.thanks
When you turn the key on, does the "Full Engine Power" light come on? On the 1990's, the light is set by the ECM, so if it is not on (and the bulb is good), it usually means the switch is not sending the ECM the go-ahead.
2nd Gear
full engine power
Hi Many thanks for you reply the light seems to work sometimes,so im sure the bulb is fine
I had to have mine changed out a while back ago (while under warranty). The light would go on briefly, then while driving, would go out. If it goes on sometimes and not others, it's the switch.
