Battery size?
Battery size
I know it is a group 75 battery. I have an Optima in mine, however, it requires some minor modification to install. At the bottom you will see the physical dimensions of the battery to fit our ZR-1s. The info below was clipped from an Interstate battery link.
http://www.interstatebatteries.com/c...nths+++700+CCA
Hope that helps.
SPECIFICATIONSCUSTOMER REVIEWSALSO FITS
Product ID: MTP-75
Amps: 875
Cranking Amps: 875
Cold Cranking Amps: 700
Voltage: 12
Termination: S
Pro-rata Warranty: 85
Weight: 32.8
Width: 7.25
Length: 9
Height: 7.63
Hope that helps.
Product ID: MTP-75
Amps: 875
Cranking Amps: 875
Voltage: 12
Termination: S
Weight: 32.8
Width: 7.25
Length: 9
Height: 7.63
