Need help!! Major problem!!
any help guys? im hoping its an oil pan gasket but from the looks of the pictures i hope its not a main seal..looks like my show season is gonna be cut short after only one car show
Don't go crazy they strip easy, bu maybe they have backed out?
yeah i was hoping it isnt a rear main seal or something since its at the front but as far as the sensor..check for leaks around that or check for bad sensor? and is there an oil overflow?
Aside from loose pan bolts about the only thing that would spew oil like that at the front of the engine would be where oil is under pressure. That confines your search a lot, and the oil filter housing and its various connections are a prime suspect.
Smoke, you said... Can your friend be specific as to whether it was from one side or the other?
Look at the exhaust headers/manifold. Is one side showing signs of burnt oil, or at least more so that the other?
I'm going out on a limb a bit, but the oil filter housing or one of its attending connections or sensors is a prime suspect, especially if it appears to be coming from the passenger side/front of the motor. Oil is under pressure there, and even a small breach somewhere will result in a leak of the magnitude of yours. Fortunately, everything about that housing is easy enough to inspect:
- As mentioned, there are the two "AN" type oil cooler connections at the oil filter housing.
- There are 3 bolts that hold the filter housing to the block. 19# of torque with some blue LockTite might be all that is needed. Or, Jerry's Gaskets can fix you up with a fresh gasket.
- There are 3 sensors attached to the filter housing; two of them are easy to get to, and one (THEE one that is apparently prone rupturing - because it is hard to get to
) is on the bottom of the filter housing.
If you don't have a problem there, and especially if it turns out that oil is blowing out of the dipstick, check you PVC valves and tubing.
Keep us posted, and come visit the ZR-1 Net Registry. The depth of talent residing there exclusively is awesome!
P.
P.
as far as the smoke it was out the drive side the most but a hint of blue on the passenger side..i have aftermarket headers w/ cat delete and as far as i can tell they are pretty beat up...thinking about putting the stock ones back on while i have it on the lift along with replacing the gaskets for the exhaust manifold
i'm already on zr1 registry (Need4Speed90) but havent gotten the chance to post yet
thank you!!!! getting it up on the lift on wednesday and checking everything out..hopefully its the problems you described..the oil filter assemly sounds like the problem along with the coolin hosescongrats on the prototype rebuild btw bringing the pride back to life
Have you brought your car to Corvettes of Carlisle? If you haven't, you will be amazed at the amount of ZR-1's there this year!
There is a group of hard core ZR-1'ers very close to you in "WAZOO" land... Have you noticed the posts? Many Z owners from VA, MD, PA, NJ, and DE helping each other out with maintenance / issues for the past few years.
Take a look on http://www.zr1.net/forum/ LOTS of owners posting up help wanted and others posting up answers.
David
Daniel
Daniel
cant wait to get this problem behind me..thanks guys
sorry its been awhile to post..ive been busy working
- The big one on top, next to the oil filter = "oil pressure sensor"
- The little one down and stick out toward the front = "oil temperature sensor"
- The one on the under side of the oil housing = "oil pressure switch"
ALL of these are available at AutoZone, I discovered. They go by different part numbers, depending on the vehicle, but the are common and used on several different cars, I'm told.
Hope this helps
P.
plenty of ZR-1 guys in your area.
go to the zr1 net registry and look them up and see if they can give you a hand.
come on up and see the wazoo guys and we'll throw it up on the lift and fix the beast.
it's what we do. don't dispair, the lt5 is a more smiles per miles option that will keep you grinning. I have had more fun in this car than anything else I've had and I've had alot
Besides the oil smoke coming up the passenger side firewall the engine isn't running well after it warms up. No power when accelerating (bogs down). No diagnostics codes. I did notice that the wires to a sensor under the TPI runner are stripped and may be shorting out.
Thanks!
-Terry
Good luck!
