VA emissions shop need help!
OK, can't stretch it out any longer
I need to find a va emissions shop that has an exhaust gas analyzer and will work with Marc on a mail order chip tune to get this beast through emissions. I had Ed from VA Speed lined up but he has moved on and honestly they are a bit far away.
need help!!! I have temp tags until end of July but I doubt they will do another set for any longer
I talked to graham @ LPE and he gave some good advice.
go back to an open loop chip to give full control over the fuel trims, lean it out, and advance the timing
I'm at 138 HC now and need to get this big 234 camed beast down below 48
I have the secondaries removed but can always put in gasket with no hole to just block the port and run on only the primary injector
wazoo boys, help me out brothas
I spiked the gas with denatured alchohol last time and got the car down to 96 HC might try a bit more with some fresh cats which is the majority of the problem my random stainless cats are 4 years old and don't clean up the exh nearly as well
going to try and mount up some fresh cats and give it a go
but thanks very much for the help and advice.
I'm going to give fresh cats and a some alchy, seafoam a try
anyone have any experience with cleaning the car up with seafoam?
the LT5 is a carbon machine and having a fresh clean engine sure can't hurt.
might have to block off the secondary ports too. gotta go find my old LPE chip which is open loop to try some alchy in the gas and see if I can lean er out a bit.
Ron whats the ratio for denatured alcohol?
I have a test comming up dont know if I will need it or not , reinstalled the stock chip, stainless works headers with air tubes and stainless works cats.91 did not have an egr
with the stock cams you should still be OK and the alchy doesn't always help with closed loop as the chip will see the o2 sensor as lean and add more fuel
I'd do the following
get the car very hot
run the temps at 210 or so
fresh oil, plug and air filter
give it a try using the stock chip
running seafoam through can "decarbon" the engine preparing for the test, but do that before you change the oil
good luck
