Plenum Electrical Help Please
Forward most section of the IH.
The other thing that some eliminate is the canister purge system which would have a connector under plenum.
Is there a purge solenoid under there and a secondary port solenoid:
Is this hardware all still under the plenum, the pump of course would be up front in the vicinity of the RH headlamp but mounted low down by bumper impact bar:
There is no vacuum canister.
No canister purge system.
None of the devices in your thied picture are present.
The drivers side plenum vacuum(pic #3) is capped, no vacuum lines.
Obviously I am an LT5 n00b and am tiptoeing my way through all this.
Can you Dick and Jane me through what the absence of these components mean. I absolutely love the machine and am not interested in addind or subtracting pieces and parts. All I want is a correct idle.
I'd say tidy it up, button it up check the MAP at the extreme rear center underneath 1 single very short hose and see what you've got. Then I guess I would start at the booster and work towards the engine, the check valve etc.
Enjoy - your not a plenum noob that's for sure!!
Thanks again.
Muffin
Thanks again.
Muffin
As for the torque spec, I believe it is about 19 ft# for the plenum. No way will that little bit of torque bend the ears of the plenum. So, if they were bent, my guess is the screws were driven in with an air impact wrench! And, if true, it is a wonder the threads were not stripped out
BTW, long as you have the plenum off, NOW might be the time to clean up the copper ring connection in the starter solenoid, if you haven't already done so. The copper ring is slammed against the two internal connection posts to complete the circuit to the starter armature.
Over time (at about 35k miles +) the ring becomes pitted and the contact posts need to be changed. A little elbow grease and emory cloth will fix up the copper ring, good as new. And, if the high-current contact posts need to be replaced, I saw them on ebay for about a whopping $6.00 for a pair of them.
Apologies for veering off topic, a little.
P.
Also, you might want to block the air horn with a hard cover book or very thick piece of cardboard. This should stall the engine, but if not, will make the vacuum leak a little louder and easier to find with carb spray or some other form of enrichment gas like propane.
purge solenoid is still present and functional, was replaced with new solenoid when charcoal canister failed and blew charcoal pellets into the old solenoid. Solenoid connector is red plastic body, if I recall correctly.
2-wire connectors could only be the coolant temp, AC compressor clutch, purge, and vacuum solenoid for secondaries <--- this would be unplugged since that solenoid has been deleted.
