ZR-1 Black wheels A-molds OEM
I have a set in great condition. 2 Frt 17x9.5in x 56mm offset 2 Rr. 17x 11in. x 50mm offset mounted with Kumho V-Racers DOT 275/45 315/35 with one tract day on them. Located Eastern PA. $1200 local pickup. These wheels also mount on the Blue GS I think ???
Your 50mm 11" would require a spacer to be run on a ZR-1 for correct appearance. The ZR-1 11" is done in a 36mm offset because of the "body width"!
Yep, now it all comes back, these were called the ZR-1 wheel with a GS offset ?? or do I just call them A-molds and folks will know what they are ??? Good news is they are the OEM, Not the aftermarket repos. I used them only for the track on a C5. thanks guys
The telling tale would be the casting information on the "back-side" that's the "identifier" and nothing else. A buyer will want that information so you might as well tackle it now. They'll also want snapshots I guess but the identifier is the casting information.
