C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Long Start
Old Feb 6, 2013 | 06:35 PM
40ZR1's Avatar
40ZR1
Default Long Start
My '95 Z takes longer to start than it did before. I remember reading an article, although not about Zs, that long starts were a problem with the fuel pressure leaking down.
I'm not familiar with the new engines, can someone confirm/explain this? And what would be the fix?
Or what could be the problem/fix.
CJ
Old Feb 6, 2013 | 06:55 PM
Dominic Sorresso's Avatar
Dominic Sorresso
It also takes two revolutions for the cam and crank sensor to synch up so spark isn't really happening until the Ignition Module confirms #1 position.
Old Feb 6, 2013 | 07:13 PM
alwayscode390's Avatar
alwayscode390
Do you have new injectors? ---
Old Feb 6, 2013 | 09:02 PM
40ZR1's Avatar
40ZR1
Thanks for quick replies. My car has 30000 miles and has had no engine work/tune up. Once it starts, it's OK. Just wondering if the long start could be fuel leak down as I remember reading and something I could check with the help of the forum.
CJ
To Long Start
