FS: 1992 ZR-1 White/White- 20K miles $25.5
1992 ZR-1 # 315. White/White. 20,300 miles. 1 of only 12 White/White cars built in 92. Spotless Carfax, can provide.
Original paint/panels. No bodywork/accidents/stories. Garage kept.
Have both tops, bronze and painted, with storage bag.
Interior: White leather interior in excellent shape. Slight wear on Driver's side outside bolster, otherwise no cracks/flaking/tears. Seat bladders inflate but only hold air for a couple hours. Replaced all the Bose amps, all gauges work as they should along with the original Bose radio, door lock/windows, etc. The only interior piece perhaps needing to be replaced is the rollup cargo shade: in good shape but it doesn’t retract any more. Rear hatch struts works as they should. ZR-1 black cargo mat. Have original power Key and spare regular power key.
Exterior: Original paint, a couple areas touched up due to typical use but no flaking/peeling or other issues. All exterior lights/lamps work as they should, including headlight motors.
Mods: Car has been sorted out. Intake and cam covers have been powdercoated and stainless steel bolts installed. Intake has been ported. RC Injectors installed for primary and secondary injectors. Marc Haibeck chip. Corsa cat back exhaust. Shelby Series 1 wheels with almost new BFG KDW tires. Have original Sawblades & GSCs that came with the car.
New pilot bearing installed 700 miles ago after original one pulled out of crank. replaced with updated roller bearing so no longer issue.
Upkeep: New fluids throughout, including rear end, annual oil changes, gearbox, coolant, fuel filter, etc. All quality Royal Purple/Mobil/Redline used. Just changed the serpentine belt and installed new plugs in the last 3 months. Brand new powerstop rotors all the way around with Grand Sport black calipers front and rear. New brake fluid flush annually.
Extras: Have a reproduction window sticker from NCM before they stopped printing the,. Also have a repo build sheet. The originals are still in the car and you can see the one behind the tank when pulling down the spare tire. Have the CD collection of training manuals, LT5 work manuals etc.
Notes: The driver side wheel has paint missing due to brake fluid from a leaky bleeder. Pass side rear wheel has 2 inch minor curbing, very light. Otherwise everything operates/functions/looks as it should. Light delamination on the original windshield. Not cloudy, can still see clearly out of it.
Original Sawblades with original GSC tires included.
Car is located in Los Angeles. Will ship at buyers expense. Cash/Cashier's check only.
Clean and clear title. Happy to answer any questions/send additional pictures.
Received 3,043 Likes
St. Jude Donor '05
Getting a smog and Ca title may help your goal here youll have to anyway to sell it to someone out here
