wiring routing for the oil temp sensor
I am throwing a code 52 which is low oil temp. problem is the gauge in the car reads just fine . my ? is does the wiring go from the sensor to the gauge then the ecm or re thee 2 sensors ????
Same sensor just different terminal. Terminal B DRK GRN/ORN to the ECM and terminal C DRK GRN/WHT to dash. Yours is a '90 I guess?
The Multiple Functions of the Oil Temperature Sensor
Was just wondering if 1991 is any different since you mentioned 1990?
"When the key is in “Full” power position, the ECM enables the secondary operation only if no trouble codes are stored and other criteria are met such as; engine oil temperature (not too hot or too cold)."
See ECM Code #52 ZR1 ECM CODES 1990 TO 1992
Thanks for the information
The Oil Temperature Sensor Terminal B or circuit B discontinuity would prevent Full Power operation it would appear.
thanx for all the info guys . the plastic is broken around my sensor so I a mwill ing bet the connector isn't making solid connection . ordered one from jerry .
