C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
General Info
Old 09-25-2015, 07:33 PM
chasboy
chasboy's Avatar
Oldtimer
Default General Info
Hi all, I'm a former C5Z06 owner, and was wondering if there is a sticky of general info on C4's, like certain years to avoid, quirks/problems, etc?
Thanks!
Old 09-25-2015, 10:46 PM
Dynomite
Support Corvetteforum!
Dynomite's Avatar
Thanks!
I assume you are talking ZR-1s (1990, 1991, 1992, 1993, 1994, and 1995 ZR-1s)?
If so....there is no certain year to avoid
Stock with original injectors...Replace Injectors.
There is a bit more in my Signature
Old 09-26-2015, 08:06 AM
Kris_K
Kris_K's Avatar
Isn't only the 90s which need updated injectors?
Old 09-26-2015, 09:56 AM
Dynomite
Dynomite's Avatar
I think 90-92 can use New SS Injectors as the Injectors are one item that just start to crap out after years of service. I replaced Injectors on both 1990 and 1991s for example. Just check the Resistance and you might see a few Injectors out of spec (I think 12-13 ohms) on any year ZR-1....but let the boys who have the 93s, 94s and 95s respond to that question.
Marc Haibeck suggests "When the ’90 – ’92 injectors were designed it was not known that ethanol would be utilized as an additive in fuel. Today ethanol is a popular fuel additive. Ethanol causes the solenoid coil shorting problem. Rochester Products improved the ’93 - ’95 fuel injectors for ethanol compatibility"
Checking Injector Resistance with Plenum in Place TIPS
Old 09-26-2015, 01:01 PM
zr-1 guy
zr-1 guy's Avatar
no, they all need replaced.
Old 09-26-2015, 01:14 PM
Kris_K
Kris_K's Avatar
What are the symptoms of bad injectors? My 94 has 65k miles and she runs fine.
Old 09-26-2015, 01:46 PM
chasboy
chasboy's Avatar
Oldtimer
No, not specific to ZR1's, I'm thinking about a decent driver to fool around with, no more than $10,000.
Old 09-26-2015, 05:46 PM
zr-1 guy
zr-1 guy's Avatar
that's lt1 money...
Old 09-26-2015, 05:47 PM
zr-1 guy
zr-1 guy's Avatar
first it goes rich, then lean, then if they're bad enough you'll hear a knocking at idle.
To General Info
Quick Reply: General Info
