91 code reading
The ALDL Fault Code Flasher/Eraser can be plugged into the present ALDL Socket under the Drivers Side Panel. The ALDL Fault Code Flasher/Eraser will ground the appropriate connectors of the ALDL when depressing and holding any of five Buttons depressed and turning the ignition ON....(not all the way to START). The Fault Codes are flashed on the Panel just above the Bose Radio and the CCM Fault Codes flashed on the Speedometer Cluster. This ALDL Fault Code Flasher/Eraser Module has a 12 Pin ALDL Connector which is compatible with 1990, 1991, 1992, and 1993 ZR-1s.
Green is ECM the one you are mostly interested in for Engine Issues.
Yellow SRC or Ride Control....FX3 shocks are Yellow.
Black is ABS....Wheels are Black.
CCM is White Elephant.....as the codes are read on the Speedo Cluster....
Red is SIR or INFL REST .......the HOT Button.....or the Button to check the Issues related to Safety.
The Fault Code Flasher will read:
1. ECM (SERVICE ENGINE SOON on Panel) Green Button
2. SRC (SERVICE RIDE CONTROL on Panel) Yellow Button
3. ABS (SERVICE ABS on Panel) Black Button
4. CCM (CCM Fault Codes on Speedometer Cluster) White Button
5. SIR (INFL REST on Panel) Red Button
It will have 5 colored mini switches (Push Buttons) mounted on a Billet Aluminum small block connected to an ALDL Connector (24 inch lead) that plugs into the ALDL under Drivers Side panel.
To Read the Fault Codes while sitting in the Drivers Seat......just plug the ALDL Fault Code Flasher/Eraser into ALDL and push/Hold Green Button for ECM (Yellow Button for SRC, Black Button for ABS, White Button for CCM, Red Button for SIR then turn the ignition switch ON (Do NOT start the engine) and see the Fault Codes flash on the Panel above the Bose Radio.
SERVICE ENGINE SOON........................................ ......................SERVICE RIDE CONTROL
SERVICE ABS ........................................ .....................................CCM Fault Codes
INFL REST
To Erase Fault Codes....Depress/Hold the appropriate Diagnostic Button and turn the Ignition Key ON....(not all the way to START). Wait for the Diagnostic light to start flashing for the Button Depressed. Release the Button for 3 seconds and then Depress/Hold the Button for about 3 seconds and Release. Turn the Ignition Key OFF.
To check that Fault Codes are Erased Depress/Hold the appropriate Diagnostic Button and turn the Ignition Key to On (do NOT Start the engine). The Code 12 should appear continuously indicating ALL Fault Codes are cleared.
Do you have an MT2500? I would love to be able to clear all systems codes with the MT2500.
As far as why you are having suspension code reading problems and I am not is unknown to me.
