DIY Top End Porting
#101
Thanks for the info. I am probably going to leave the car alone for now. It runs so well. Like a new car. My 95 is my play car. I am seriously considering one of Pete's engine conversions. I am planning on running that car next with data logs and O2 data so Hopefully Dom can tune a few extra ponies into her before I pull the trigger on an engine upgrade.
#103
#105
#106
regarding concern over the injectors/grommet seating too "deep".........an easy fix is to install a washer under the fuel rail attaching points, which essentially lifts the injector in the housing to insure it does not go too deep if porting is extreme, and /or there has been some material that has flaked or cracked away. just fyi
#107
Thanks Jim. Good to know. At the moment I am trying to figure what the gap between the master cylinder and booster push rod should be and how to adjust for my 92 ZR1. I just posted a thread regarding this. If you have any wisdom to share I would appreciate it.
Thanks!
Thanks!
#108
even without the variable cam tech that was destined for this engine it spanked out a bit more than the 475 target and was running a caddilac ecm with a single big injector graham should be proud for bringing this one back
