Fuel Tank Capacity??
I just filled my gas tank in my 1993 Convertible The gauge showed about 2-3 bars. This is lower than I usually go. Since I was so low I was curious about how much it would take to fill so I filled to the brim. Amount filled on the receipt was 20.013 gallons. My car did not stall or stumble ran fine. No low fuel lights were on. I even sat there for 5 min or so waiting on line. This is at the station I often use a BJs with 12 pumps or so.
Any one have any thoughts on this?? In the past with other cars including my '86 Coupe I never filled more than 15-16 gallons and never ran until the warning light came on. I always thought the warning would come on at 3 or so gallons which is close to where I thought I was at..
Barrier
Barrier
Capacity is 20 gallons or 76 liters. When you convert liters to gallons you get 20.0177. So it looks like you were all but dry. I'd say something is wrong with the fuel gauge sender float in the tank. Have the fuel pumps ever been changed? Something might have gotten bent. Otherwise it may just be a malfunctioning sender.
H
H
Zen Vet Master Level VII
I bench tested everything and the gauge read dead on. It read correctly when I put it back together and seems to be good thus far.
