C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
map sensor
Old 08-09-2017, 12:10 PM
slovie
slovie's Avatar
Default map sensor
Is there anything I should know before changing out the map sensor? before and after on my 91 zr1 running rich right now
Thanks slovie
Old 08-09-2017, 06:03 PM
wfot
wfot's Avatar
​​​​​​no it should be pretty straight forward. Plug and play. If it has been runnig rich for a while, you should blank the computer to help it relearn faster. And i would go with GM parts not generic ones. The entire fuel curve depends on what that part is telling the WCU.
Old 08-11-2017, 10:53 PM
Rkreigh
Rkreigh's Avatar
yes check the little hose and make sure it's changed out
you'd be surprised how much oil finds it way in and tends to gunk up the work and swell the hose until it falls off
you'll know it when it does, and now is the time!!
Old 08-12-2017, 07:11 AM
slovie
slovie's Avatar
Default dealer item?
is the hose a dealer item? I have never had it blow off the fit is very tight must be replaced? Dealer item? Thanks for info
To map sensor
Quick Reply: map sensor
