map sensor removal zr1
looks like no easy way to remove map sensor without removing the lower bracket? or maybe I'm not patient enough or my fingers are to big any help would be grateful.
It's 2 T30 torque screws holding the bracket to the rear of the plenum. Should take you 5 min. to remove it. I had mine off a few weeks ago to do my fuel injectors. Just don't drop the 2 screws.
5 minutes
Really it took me 5 minutes to get in position that wouldn't throw my back out of shape, along with dropping the rubber 3 hole grommet down to the trans. my next project is to jump out the clutch switch for a starting problem, looks like a 1/2 day project with all the dismantling of dash screws and carpet panels along with hanging upside down is no fun thing .
