C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
92 LT1 issues
Old Nov 14, 2017 | 06:30 PM
ajcajc's Avatar
ajcajc
Default 92 LT1 issues
Is it normal for a 92 Corvette with 27,000 miles to have the main rear seal ,crank seal, rear wheel bearings & manifold gasket to be replaced?
Old Nov 14, 2017 | 06:46 PM
RICHARD TILL's Avatar
RICHARD TILL
No, Not normal at all. There must be a reason.
Old Nov 18, 2017 | 10:22 PM
Kevova's Avatar
Kevova
I would clean or have engine cleaned. Then add oil dye. After 20 or more miles black light looking for source of leak. Need to get car on ramps or a lift so you can get a good leak from underneath. It could be " China wall" the ends of intake use rtv to seal it to block. Oil can seep past old rtv and run down near front and rear seals.
To 92 LT1 issues
