C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
OZ Wheels
Old Dec 13, 2017 | 06:40 PM
C4_Stick's Avatar
C4_Stick
Default OZ Wheels
17" OZ Wheels. I'm not sure of the exact width and offset but I can try to find it for you if you need (I'm almost sure they are the same specs as the stock ZR1 wheels). They are mounted with Nitto NT05 tires (at least 80% tread) sized; Front: 275/40/17; Rear: 315/35/17. These were mounted on a ZR1 and did not stick out whatsoever; actually they were at least a couple of inches inside/inset of the wheel well. They are very clean. $2500 for complete but am happy to separate just the rims or tires if you're only interested in either or...we can figure out the $$ if that's the case. If you would like to call/text: 415-572-5399..Dee Thanks!
