C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
1991 Rear shock question
Old Jan 11, 2018 | 05:50 PM
mistergn9's Avatar
mistergn9
Default 1991 Rear shock question
So having trouble locating some rear FX3 shocks.
The question is what is the difference on the 92-95 rear shocks? Can they be used in place?
Mike
Old Jan 11, 2018 | 06:52 PM
Dynomite's Avatar
Dynomite
Mike
Bilstein Shock Applications and Self Alignment TIPS
In regard to applications of FX3 Shocks 90-91 and 92-later.......
You can't just change out the gear on top as entire rod needs to be changed due to the valving holes. You can use 92 FX3s in 90-91 Application if you upgrade to the newer controller and vice-versa.
Old Jan 12, 2018 | 09:29 AM
Goldcylon's Avatar
Goldcylon
Cliff is correct. The shocks for the 89 FX-3 equipped cars are the same as well. The early system FX-3 for the C4 was 89-91 and in addition to the top gears the internal valving is different. GC
Old Jan 12, 2018 | 10:51 AM
ccmano's Avatar
ccmano
What’s wrong with the rear shocks? If they are simply worn out, have them rebuilt. Apparently Bilstein no longer rebuilds oem shocks but other places do.
https://www.speedwaymotors.com/Info/Shock
http://deltavee.net/services/
H
Old Jan 12, 2018 | 04:24 PM
mistergn9's Avatar
mistergn9
H
Yes just old a tried. I will look into getting them rebuilt thanks for the info.
Old Jan 12, 2018 | 04:54 PM
RICHARD TILL's Avatar
RICHARD TILL
Mike, I have a full set of shocks but its been so long ago when I bought them, I forgot what model year they fit. How do I tell the difference?
Old Jan 12, 2018 | 06:46 PM
mistergn9's Avatar
mistergn9
I am not sure either. Can you PM the part numbers and I will figure it out.
Mike
Old Jan 13, 2018 | 07:07 AM
Z51JEFF's Avatar
Z51JEFF
I have the receipt from the place I bought mine a few years ago. I wouldntbbother having them rebuilt if you can find new. I sent mine to a reputable shop and the guy tried to scam me. Ended up costing him a new set of OEM shocks.
To 1991 Rear shock question
