C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
2016 Z06 wheels on a 94 ZR-1
Old 04-26-2018, 05:24 AM
Norwegianmopar
Norwegianmopar's Avatar
Default 2016 Z06 wheels on a 94 ZR-1
Guys, do you know if 2016 Z06 wheels will fit on a 94 ZR-1?
https://www.hubcaphaven.com/p/23362/...-23347213.html
Old 04-27-2018, 02:22 PM
biggiefl
biggiefl's Avatar
At $719/rim they are not getting anywhere near my ZR1
Old 04-27-2018, 09:07 PM
JimZRyd
Support Corvetteforum!
JimZRyd's Avatar
St. Jude Donor '12
I’ve got 18x10 on the front and 19x12 on the rear with 285’s and 345’s respectively. With the right offset and some trimming you can fit almost anything you want👍🏻
Old 04-27-2018, 09:56 PM
Dominic Sorresso
Dominic Sorresso's Avatar
Originally Posted by JimZRyd
I’ve got 19x10 on the front and 19x12 on the rear with 285’s and 345’s respectively. With the right offset and some trimming you can fit almost anything you want👍🏻
Jim,
Hiw do u avoid inner fender well rubbing?
Old 04-27-2018, 10:03 PM
JimZRyd
JimZRyd's Avatar
St. Jude Donor '12
Hey Dom! No rubbing at all on the front using 285/35/18’s, with the rears, 345/30/19’s, I had to trim just a small amount of the inner part of the plastic wheel well towards the bottom of the plastic. Really not much at all. I drove it around the block and let the tires mark where they rubbed, then brought it back and dremeled those spots out.
Old 04-27-2018, 10:04 PM
JimZRyd
JimZRyd's Avatar
St. Jude Donor '12
Corrected my earlier post...18x10 on the front
Old 04-27-2018, 10:29 PM
Dominic Sorresso
Yes that’s what had me confused. Have the same setup on mine and I use duct tape in the fender well to indicate rubbing. I have coilovers and needed to raise the front about 5-6mm. The tire was taking the silver off the tape and would rub on some dips.
Old 04-27-2018, 10:35 PM
JimZRyd
JimZRyd's Avatar
St. Jude Donor '12
👍🏻I also am running coil overs. My rears were perfect right out of the box. Haven’t adjusted the fronts..kinda feel I might lower them a bit, but don’t want to scrape.
Apologies to the original OP for high jacking his thread. Hope the infos been useful!
Old 04-28-2018, 08:11 PM
Z51JEFF
Z51JEFF's Avatar
I’ve found there is a small area at the top front of the rear liner that needs to be trimmed as well.
To 2016 Z06 wheels on a 94 ZR-1
Quick Reply: 2016 Z06 wheels on a 94 ZR-1
