Doug Rippe Motorsports "Widow Maker #001"
Listed F/S on Minneapolis Craigslist, I know nothing about the car, just passing it on to the guys that do know ZR1's
https://minneapolis.craigslist.org/c...660233237.html
Wish I had a spare $25k just lying around, what a steal.
The DRM upgrade alone probably cost more than that.
'Crabs
'Crabs
I have a 1991 zr1 Black/Black GM told me it was a preproduction black widow and 1 of 6 vin#995 it has a three position power key total hp 575 hp autograph LT5 by corvette chief engineer
im just going off of what GM told me I’m trying to see for sure and I found the e-prom and called DRM and they told me it was a stage 2 this is the second EPROM I found in the car Doug says it’s preproduction black widow as well and used by the zr1 race team
Pretty cool, you should get the full story documented, whats the 3 position power key? What are the list of mods?
It would be interesting to find out more about the car, while there are 8 documented black widows I talked with Geoff Jeal and he noted that he had records for 14 actually
Probably stating the obvious here, but let’s not confuse the “Black Widows” with “Widow Makers” here. Based on my minimal understanding ( someone will no doubt correct me) “Black Widows” were the first and had some degree of “factory” involvement.” “Widow Makers” came later and were Rippies solo attempt to capitalize on the “Widow” name and performance.
H
H
H
H
Scott
I talked to Doug about the Widow Maker name, and it was not a name that Rippie Motorsports created. It was a name made up by one of the early customers of a DRM600 engine (applied to his specific engine only, and was not a series or engines or a particular build). It was never a "thing" like the Black Widow series.
Scott
Scott
H
Received 3,043 Likes
St. Jude Donor '05
That would have had the lighweight rear bumper then too right?
Those are unobtanium.
Scott
Car did not originally go to DRM, but t has been there for repairs to (I believe) a broken cam. DRM built the engine, which was then sent to a Chevrolet dealer for install. The owner thats had the engine built was pretty full of himself and did a lot of self=promoting.
Scott
Scott
