C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
fix loose steering wheel
Old 09-02-2018, 04:27 PM
doityourself
doityourself's Avatar
Default fix loose steering wheel
1996 zr1 c4 that air bag scares me ,how to unhook air bag and find out why steering wheel is so loose ?
Old 09-05-2018, 10:14 AM
ccmano
ccmano's Avatar
That’s a common C4 problem. A bushing in the steering column tilt mechnisim wears out. Here’s the fix.
http://www.zr1specialist.com/HAT%20W...lumn%20pin.htm
H
Old 09-05-2018, 01:40 PM
doityourself
thank you for explanation
Old 09-19-2018, 02:03 PM
phrogs
phrogs's Avatar
Its loose because people use the wheel as leverage getting in and out of the car and it wears out. Very common.
also you must have the only 96 ZR-1 built hold onto that one.
doesnt really matter as the airbags and steering column are the same for the given model year ZR-1 or not.
Old 09-20-2018, 01:41 AM
doityourself
took steering apart shaft bearings bad every thing else tite now all I got to do is get back together
Old 09-20-2018, 01:45 AM
doityourself
pins , knuckle and bolts all good and tite it was the upper and lower bearings bad
To fix loose steering wheel
Quick Reply: fix loose steering wheel
