Radio Quit Working
POSSE ZR-1 Driver
Radio Quit Working
So, the other day, the radio just stopped working. No sound from any speaker. I've done a bunch of checks in the FSM, but nothing seems to be broken. Both radio fuses OK (those secondary fuse panels are a bear to get to). CTSY fuse OK. The Amplifier relay seems to be working, at least it "clicks" when I turn the radio on. I haven't removed the relay yet as I can barely touch it behind the instrument cluster. Head unit turns on. Tunes to different frequencies OK. Don't get a Stereo indication from any known local station. Antenna goes up & down as it should. No "hiss" at full volume.
I'm a bit baffled. Is there a Mute button I may have hit?
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
This site has some trouble shooting guides, I had a bad CDM had them fix and add I-pod
https://www.carstereohelp.com/chevrolet.htm
