C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
replacement shocks
Old Aug 4, 2022 | 02:42 PM
rickjay's Avatar
rickjay
Navigator
Default replacement shocks
Hello, has anyone out there with a C4 ZR1 replaced the shocks with other than the Bilstein?
If so, what brand did you choose and why?
Is there anything needed to do with the Selective Ride Control unit?
Any info is greatly appreciated.
Rick J
Old Aug 4, 2022 | 05:14 PM
Tokuzumi's Avatar
Tokuzumi
I don't have a good answer if you are looking to replace only the shocks, but when my FX3 shocks go bad, I'm going to splurge on some adjustable coilovers. Not looking to slam the vehicle into the ground, but I don't plan to search far and wide to find someone to rebuild or replace the FX3 shocks.
Old Aug 5, 2022 | 03:37 AM
prez1967's Avatar
prez1967
i replaced my factory FX3 with lower mile units and still dont feel a difference
Have brand new Ride-Tech coilovers and sway bars waiting for install this winter
Old Aug 5, 2022 | 03:32 PM
rickjay's Avatar
rickjay
Navigator
Read somewhere that Bilstein will not rebuild the original shocks but will do their aftermarket ones...just some food for thought.
I did just purchase a set of QA1's single adjusters and will most likely be installing 'em tomorrow.
Old Aug 5, 2022 | 09:14 PM
Tokuzumi's Avatar
Tokuzumi
Do the aftermarket Bilstein shocks perform exactly as the original FX3 shocks? Or does Bilstein just provide a resistor to plug into the factory connector, and then the selector switch becomes a fidget spinner?
Old Aug 6, 2022 | 10:35 AM
RatRacer's Avatar
RatRacer
The aftermarket FX3 Bilsteins work exactly like the OEM shocks. The only difference are the labels/stickers and generic performance valving.
Old Aug 8, 2022 | 12:11 PM
jrtoffroad's Avatar
jrtoffroad
Did you call Bilstein directly to order?
Old Aug 8, 2022 | 01:15 PM
RatRacer's Avatar
RatRacer
I got them from Rock Auto last year.
To replacement shocks
