C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Possible Starter Issues
Old Mar 19, 2026 | 05:28 PM
KJL's Avatar
KJL
Default Possible Starter Issues
I have a 95 ZR1 that has intermittent starting issues. At one point I thought it was a VATS issue. Not so sure at this point. I have been chasing the problem for years. Never happens at home despite my attempts to simulate conditions when it does happen. I have installed the key pellet bypass resister but that did not help. Starting to lean toward the starter. When I attempted to start the car today, the security light was off. I heard the fuel pump cycle and the dash lights dimmed ever so slightly when I attempted to start. (New battery). But got no starter engagement at all. Nothing. After about an hour of repeat attempts, which is typical, it finally started. I have a solenoid rebuild kit so I think that is the only logical next step.
Any thoughts?
Old Mar 19, 2026 | 05:46 PM
WVZR-1's Avatar
WVZR-1
Jumper the 'clutch safety switch' for diagnostics? Starter solenoid rebuild is certainly possibly a fix. Would you do or maybe a 'for hire' at SGC?
Old Mar 19, 2026 | 06:54 PM
KJL's Avatar
KJL
I will try that but given my history with this issue it does not make sense that that would be the cause. Probably attempt the fix myself first. I have pretty much done everything on the car myself over the years... why stop now. SGC is quite a haul for me located in south central GA..... so if I am removing it myself I may as well attempt to fix. Do you know of anyone who sells manufactured starters for these cars..... that fit?
damn I am getting old.... been a member for 26 years. I have not been on for awhile, things have changed.
Old Mar 20, 2026 | 08:22 AM
KJL's Avatar
KJL
Nice to see you are still around. I went back and looked at my private messages and realized I spoke to you a length about repairing the starter back in 2024. You helped me aquire the parts. Thank you.
Old Mar 20, 2026 | 09:13 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
That "dreaded no start" is a real pain, isn't it?
I'm pretty sure I did every "fix" one by one. Each seemed to help .. for a while. I finally did replace the starter a few years ago.
I don't remember where I got the Remy starter, but a new one was available a few years ago.
Are you going to rebuild yours or look for a new one?
Old Mar 21, 2026 | 02:23 AM
Dynomite's Avatar
Dynomite
These cars start pretty easy with a hand push in second gear (key on pop the clutch}
"In a pinch"
Old Mar 21, 2026 | 07:40 PM
KJL's Avatar
KJL
Probably rebuild. I have the parts for the solenoid. That said if I could find one already built, I would consider just going that route.
Old Mar 21, 2026 | 07:41 PM
KJL's Avatar
KJL
"In a pinch"
hahah….. I live in middle Georgia. Not a lot of hills here. Great way to test it. I which in could duplicate at home….. just once.
Old Mar 22, 2026 | 07:16 PM
FASTAZU's Avatar
FASTAZU
2015 C4 of the Year Finalist
St. Jude Donor '16
Hope your doing well long time sense we hooked up.
Steve
Old Mar 23, 2026 | 03:38 PM
KJL's Avatar
KJL
Steve
Steve, I don’t recognize your handle. Refresh my memory please.
Old Apr 20, 2026 | 04:36 PM
KJL's Avatar
KJL
I purchased 2 solenoid repair kits about a year ago. If I recall I think you said something about having to modify it in some way. Possibly shorten the push rod? Although I recall someone saying just to clean up and reuse the old one. Do you recall any of this? Thanks!!!!
Old Apr 20, 2026 | 05:19 PM
WVZR-1's Avatar
WVZR-1
I've always suggested that a person measures the one they remove before assuming what they've maybe bought is just replaced. Glean and reuse sounds good. Do the kits you bought include the plunger? It's been a while.
Old Apr 20, 2026 | 05:49 PM
KJL's Avatar
KJL
Yes it does. Not sure where I got the information for these kits but they should be a very close match. I will clean up and reuse what I can for sure. Do you still have your car?
To Possible Starter Issues
