Differential Question
I have never used the diff. drain plug, probably a good time to install if you want it. It is not that difficult to pump the old fluid out through the fill hole in my opinion.
Regards,
Brian
It was easy and straight forward to drill and tap the hole, there are plenty of measurements online where to drill if you don't get the kit with instructions.
Any quality LSD oil should be fine, however do not skip the gm LSD additive.
It's readily available everywhere even here in Oz.🙃
A word of warning the pinion bolt is a bitch, crack it loose with diff in place and tailshaft removed. it needs a lot of torque to undo, but the seal can be replaced without affecting the pinion position / crush tube just follow the shop manual torque specs.
http://www.summitracing.com/parts/ado-10-4003
I wonder if you will get carried away and clean / detail the whole rear suspension and replace the bushes universal joints like I did, then you will not want to drive the vette in rain ever again when the car is cleaner underneath than most cars paintwork.... 😆
Hey we are a bit crazy about our vette's needing to be perfect condition here in Oz 🙃
