C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Backfire!
Old May 18, 2003 | 11:42 PM
Iliad's Avatar
Iliad
Default Backfire!
I picked up my 1992 ZR-1 from storage last Friday after 7 long months of winter. The battery was completely discharged, so I had to jump start it. It took a few tries to get it running. The first try resulted in a backfire from the engine. When I drove the 20 miles home after gasing up, the engine was missfiring and the check engine light came on. When I arrived home I ran the codes and got a MAP sensor failure. This immediately reminded me of a article on the ZR-1.net site that suggested after a backfire check the PCV and Map sensor hoses. Sure enough the MAP sensor and the PCV hoses where indeed blown off. Problem solved. :jester
Old May 19, 2003 | 12:28 AM
90 Corvette ZR-1's Avatar
90 Corvette ZR-1
Default Re: Backfire! (Illiad)
Yep had that happen to me at BG
