CLUTCH SMELL
CLUTCH SMELL
Well I kind of broke in the ZR tonight, and was learning to "launch" it. In the process, I smelled the clutch for the first time.
My question is, I know this isn't good on it, but how long will the clutch last? Did I just knock off 10,000 miles of use?
Thank you!!
Roger
Thank you!!
Roger
Re: CLUTCH SMELL (94BLACKZR1)
Well it dosen't help the clutch any but here and there you should be fine.
I would say if you do alot of burnouts expect to replace the clutch at 30,000.
Of course 1 good burnout can glaze the clutch or grenade the driveline components.
Let's just say you are not going get 100,000 - 150,000 miles on the clutch if you do burnouts alot
on one of my daily drivers I have 130,000 and still have the original clutch which is in good shape -- it proves that the clutches are pretty meaty.
