C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Shift Knob
Old Aug 26, 2003 | 12:40 AM
dennismont's Avatar
dennismont
Default Shift ****
Before I break something with brute force and akwardness, how do I remove the shift **** on my '91? I bought a new white one and am not sure how the old one comes off. I assume it "unscrews" but I wondered if there is a set screw or something I didn't see.
Old Aug 26, 2003 | 07:05 AM
Rkreigh's Avatar
Rkreigh
Default Re: Shift **** (dennismont)
pry the small shift pattern plate out with a small screw driver, pull or pry the "wedge" being careful not to mar the shifter ****, and then it just unscrews.
good luck, takes a bit to get the wedge out sometimes, I put some towels on the **** and pry it out with two screw drives and somtimes some needle nose vice grips can get at it.
Old Aug 26, 2003 | 09:00 AM
USAZR1's Avatar
USAZR1
Default Re: Shift **** (Rkreigh)
Just be careful you don't pinch one of your fingers with the needle nose pliers when pulling on the wedge as it will leave a nasty blood blister.
Don't ask me how I know this. :cry
Old Aug 26, 2003 | 12:39 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
Default Re: Shift **** (USAZR1)
We dont need to ask do we Clint because you just told us :smash:
I bet that hurt!
Old Aug 26, 2003 | 06:52 PM
USAZR1's Avatar
USAZR1
Default Re: Shift **** (phrogs)
Sure did. The sad part is I was dumb enough to do it both times I've had the **** off. :lol:
Old Aug 26, 2003 | 07:09 PM
dennismont's Avatar
dennismont
Thanks to all who replied. I removed the **** with the "two screwdivers" method and it worked the first time I tried it!
Thanks again
Old Aug 28, 2003 | 01:45 PM
ZZZZZR1's Avatar
ZZZZZR1
Thanks again
Hey Dennis, get the Hurst shifter under that ****. You'll love it!
:cheers:
Old Aug 28, 2003 | 01:55 PM
415LT5's Avatar
415LT5
Default Re: Shift **** (ZZZZZR1)
I'll second that!
Old Aug 28, 2003 | 02:25 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: Shift **** (415LT5)
Oh, yeah, the Hurst is a great mod!!! :yesnod: :cheers:
To Shift Knob
