C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Help!!!
Old Feb 28, 2004 | 08:55 AM
secondchance's Avatar
secondchance
Default Help!!!
Can't find torquing sequence and lb/ft torque for intake plenum. I know its somewhere in ZR-1 net. Can someone post url??? :(
Old Feb 28, 2004 | 10:27 AM
The Lurker's Avatar
The Lurker
Default Re: Help!!! (secondchance)
Basically, just use a middle to both ends, side to side torquing sequence and everything will be fine really.Basically, start in the middle, tighten a bolt, and then go to the other side and tighten the same bolt. Work from the middle of the plenum to the two ends. Use 19 lbft torque.
Old Feb 28, 2004 | 11:35 AM
White 68's Avatar
White 68
Here you go :thumbs:
Old Feb 28, 2004 | 12:49 PM
secondchance
Default Re: Help!!! (White 68)
Thanks.
To Help!!!
