90 mill shaner throttle body
I have an LS2 ported throttle body that I may part with...its has been
ported over the winter and is brand spankin new....if anybody needs one let me know...it was purchased new from fred beans then was ported for 125....not sure exactly what its worth....$325.00
some of the NA guys swear by the ported TB's.....I am gonna put it on my car unless somebody wants it....I dont really need it with 13lb's of boost...but was only concerned about idling issues....
NA it would make no difference. Take a 1 inch tube and try breathing through it, Now put a funnel on the end of it. The funnel is not going to make breathing any different because your sucking in and the size of the tube is still the same. Now under boost you are pushing air in and not sucking, if you are forcing air in you can create a smoother area on the outside that could do something, smooth turbulence. But its simple physics... drawing through, as long as the hole is the same in the middle you could completely cut off all the material on the outside and it isnt going to flow a bit different.
