427 Forged Lingenfelter Twin Turbo Z06
- Engine removal, inspection and disassembly
- C5R Racing block. Preparation and blueprinting
- Lingenfelter CNC porting & polishing of LQ9 cylinder heads
- Comp Cams valve springs, titanium retainers
- Three angle valve job, set spring tensions
- Lingenfelter GT9 hydraulic roller camshaft
- JE forged aluminum pistons
- Total Seal file fit rings
- Manley 6.125" fully machined 4340 forged steel I-Beam connecting rods
- Computer balanced rotating assembly
- Re-assembly and blueprinting of the engine
- Two Garrett true ball bearing turbochargers - liquid cooled and engine oil lubricated
- Lingenfelter turbo compressor housings & exhaust housings with integral waste gates
- Lingenfelter twin high efficiency air to air charge coolers
- Lingenfelter custom molded silicone air ducts
- Lingenfelter 4 into 1 custom exhaust manifolds & turbo outlet adapters
- Lingenfelter turbocharger scavenge pump & turbo oil drain reservoir
- Stainless steel ceramic heat shields and stainless clamps
- Borla stainless steel exhaust system
- Two K&N 360 degree conical air filters
- High capacity fuel delivery system
- Properly sized fuel injectors
- Professional installation, testing and tuning
- Port matched intake manifold
- Ported & polished throttle body
- Lingenfelter Mini Tub kit
- HRE 3 piece wheels
- 335/30/18 rear 265/35/18 front Michelin Pilot Sport tires
- Medium Spiral Gray Metalic paint
- Chassis dyno report
- Excellent drivability, highway mileage not adversely affected
- 650 hp/660 tq on pump gas.
- 821 HP/ 907 TQ on race fuel @ 18psi
- 29,537 miles. $39,950.00
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
ttt
The seller of this car is motivated to sell - I know that the seller will entertain a serious offer! This is a great car, just waiting for a great buyer!
Give us a call and we would be happy to talk about the car!
Lingenfelter cars are very pricey to have built, so as a result people try and recoup some of that when they sell it used.
If they can find a big Lingenfelter fan they can get a little more for it but its hard because they usually aren't priced in the same ball park as smilarly built but non Lingenfelter cars.
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
At the time this car was built a Lingenfelter 427 twin turbo package was a $20000 plus package with a warranty. Lingenfelter products are very comparable to Calloway. Probably the two best Corvette Tuners in the USA. And No, I am not affilated with either vendor. lol.
Former Vendor
Lingenfelter Car Number 26
2001 C5 Z06
Lingenfelter 725 HP Twin Turbo LS1, ZO6 Package
427 CID 725 BHP / 730 lbs-ft of torque
0-60 MPH 3.2 seconds with street tires
1/4 mile 9.50 @ 145 MPH with ET street tires
Estimated top speed 230+
View time slip - October 15, 2001
Package includes:
- Custom C5R aluminum block preparation
- JE forged aluminum pistons & Total Seal file fit rings
- Callies 4340 forged steel crankshaft
- CNC Porting and polishing of LS1 cylinder heads
- Competition Cams valve springs
- Stainless steel one piece heavy duty intake valves
- Inconel one piece heavy duty exhaust valves
- Three angle valve job, checking of spring tensions & heights
- Port matched LS6 intake manifold
- Properly sized fuel injectors and high capacity fuel system
- Gaskets, spark plugs and fluids
- Reassembly and blueprinting of engine
- Lingenfelter twin high efficiency air to air chargecoolers
- Lingenfelter Cast Iron 4 into 1 custom exhaust manifolds & turbo outlet adapters
- Stainless steel / ceramic heat shields and stainless clamps
- Professional installation, testing and PCM recalibration
- Original engine reused for cores
- Lingenfelter 3 year / 36,000 mile warranty
1997-2004 Package Price $39,995.00
Stock Z06 Transmission, Stock 3.42 Z06 Rear End
Car had 9000 miles on it when it was sent to Lingenfelter, currently has 29,537 on the clock.
Paint color is not original, Med Spiral Gray was not avaliable until 03 and not on a Z06. Custom paint better than OE.
Has just been serviced and is ready for a new owner.
Intertaining any offers in the 40,000 price range.
2001 C5 Z06
Package includes:
Former Vendor
This car was originally a 650 package that was upgraded to the 427 engine at a later date. So the owner spent even more than that.
Also has the front Brembo Brake upgrade, HRE wheels, Coil over suspension, custom paint, boost controller.
This car is priced way lower than its value.
Thanks for looking.
