C5 Corvettes for Sale Classifieds: Used C5 Corvettes for sale as well as modified or stock Corvettes
WTT: Turbo BMW E36 M3 for C5 Z06 (Will add cash)
Old 07-16-2013, 10:45 AM
Mineral_'01
Mineral_'01's Avatar
Default WTT: Turbo BMW E36 M3 for C5 Z06 (Will add cash)
Want to trade my 1998 Turbocharged M3 for your Corvette C5 Z06 (any color). I will add cash on my end to make up the difference.
If a price must be posted for thread requirements it's $ (Trade is currently pending)
Up for trade is my beautiful 1998 BMW M3 in factory Arctic Silver paint. The car features over $16,087.00 in modifications and maintenance which I will list below. The M3 has right around 93,5xx miles on the clock. Interior is in mint shape. Exterior in very good condition, front bumper has a few small rock chips otherwise paint is great. Cold A/C and heat works well. At the current moment the vehicle is at TRM tuning in Cumming, GA having some top end work done to it due to a failure from a poorly machined cylinder head that I purchased at time of turbo install. All parts on this car have been replaced with factory BMW stock or top quality aftermarket performance goodies. I have all receipts and documents showing the list of mods. The vehicle will be out of the shop and dyno tuned before any trades are made. Expected hp will be 500+. If you don’t believe me, do a quick Google search on TRM tubo kits
On to the modifications:
Engine: Stock S52 3.2L block with 93.5K miles
 •Oil pan with 10AN fitting for turbo drain installed
• New BMW oil pan gasket
• New BMW rear main seal and carrier
• Resurfaced block deck to a mirror finish
• CES Motorsports cut-ring head gasket plus .070 copper spacer combo (good for 30psi of boost)
• ARP 2000 head studs
• New BMW intermediate timing chain guide
• New BMW camshaft tensioner and guide
• Schrick Performance camshafts
• Resurfaced and pressure tested S52 cylinder head
• New vanos unit
• New BMW valve cover gasket and grommets
• NGK plugs
• M50 manifold conversion with all new BMW gaskets
• AKG polly motor mounts
• Steward Performance water pump
• New Factory BMW thermostat and aluminum housing
• New BMW upper and lower radiator hoses
• New Behr S54 3 core radiator
• New BMW cooling clutch fan (not cheap imitation ones that explode under boost)
• 16” Spal pusher fan to work alongside the mechanical fan
• Provent 200 catch can (no currently installed, CCV vented to atmosphere)
Turbo kit:
TRM stage II kit: (cost $6,400 alone)
 •Garrett GT35R ball bearing turbo charger
• SPA T4 bottom mount manifold (ports cleaned up with grinder)
• Tail 38mm waste gate routed to recirculate from manifold back into exhaust- no open dumps here
• Stainless steel braided oil feed line with restrictor
• Silicone water feed and return lines
• Push-lock oil drain hose and fittings to 10AN oil pan
• TRM motor mount arm
• Powder coated turbo inlet and K&N filter
• Powder coated charge pipes 2.5” out to 3” (this system routes above the subframe to keep maximum ground clearance and retains A/C)
• 600+ hp rated intercooler and frame bracket
• Synapse BOV
• TRM Blow through MAF
• 60LBS injectors
• Rally Road 340LPH drop in fuel pump
• 3” downpipe to 3” Pypes resonator out to 3” Magnaflow muffler
• Factory tuned DME for excellent drivability
• NXS manual boost controller
Transmission:
BMW ZF 5-Speed:
•Fidanza 14.5LBS aluminum flywheel with new crankshaft bolts
• New BMW pilot bearing
• UUC Segmented Kevlar clutch kit and pressure plate (good for 500lbs of torque)
• New BMW pressure plate to flywheel bolts
• Sachs throw out bearing
• Rally road pivot pin
• New BMW input shaft seal
• New BMW clutch fork
• New slave cylinder
• Red Line fluid change
• New Guibo
• Dinan short shifter
• New BMW tranny mounts
Suspension:
• H&R lowering springs
• Strut tower brace
• Motor mount reinforcement plates
• Sway bar reinforcement plates (not installed yet)
• R-tab reinforcement plates (not installed yet)
• Breyton 18” competition wheels
• New Kuhmo LE tires
• Active Autowerks differential brace/support (not installed yet)
Interior/exterior
• New door handle trim pieces
• New cowl vent plastic
• Euro clear tail light and side marker conversion
• Various other trim pieces (some not installed yet)
• Euro Mtech M3 steering wheel (not installed yet)
• Ortiz Customs gauge mount to take place of sunglasses holder
• Prosport Halo series boost and wideband gauges
There are probably quite a few things I am forgetting but onto some low res/quality pics.
Before turbo install and pics taken by the PO:
And turbo install
URL=http://imageshack.us/photo/my-images/441/dscf0976f.jpg/][/URL]
- - - Updated - - -
Incase anyone is interested more details and info about the BMW can be found on my build thread here: http://forums.bimmerforums.com/forum...eek-(pic-heavy)
*Also I should note should anyone be interested in any kind of trade, the deal will be handled by a family member. Reason being I am an overseas contractor and will not be home till late November. This will not be a problem, the title to the car will be signed and ready for your ownership. If you are local to the Atlanta area you should be able to vist TRM Tuning (Cumming,GA) to see the car in person. I will notify the shop owner that someone wants to look at it and while your there you might get to see it get dyno tuned
Quick Reply: WTT: Turbo BMW E36 M3 for C5 Z06 (Will add cash)
