FS: C5Z 2002 Silver, 149k miles, with NEW ENGINE & CLUTCH
Have a Z06 for sale, she's been in my garage since 2013.
It has been my weekend worrier/AutoX/Trackday toy.
Not a show car, but a great driver's car.
She handles nice and predictable, does not overheat on track for entire session.
New blueprinted engine / Clutch and flywheel has less than 2000 miles
Around 420whp with stock headers.
Pass CA emission and clean title registered in CA.
149k on chassis
[Engine]
Blue printed engine rebuilt with all receipts
Engine machine and build
Improved racing Oil pan baffles
Lower pan gasket
New Flywheel bolts
Monster stage 2 clutch kit with light weight flywheel
New power steering hose
New serpentine belt
Pro balancer
Coolant temp sensor
Knock sensor
Knock sensor harness
Engine oil pressure sensor
Engine oil sensor connector
Crank position sensor connector
New denso spark plugs
Spark plug heat shields
GMPP spark plug wires
New 160 thermostat
Exhaust studs
Exhaust nuts
Port and polished 799 heads
Valve springs
Performance seats, seals, dual springs, retainers
Valve cover gasket
Fuel filter
Stainless steel braided teflon racing fuel line and swivel hose ends
Comp cam
Flipped intake mod with K&N intake
Setrab 625 oil cooler with lingenfelter performance sandwich plate
Dewitt radiator
Borla stinger exhaust
And many more...
[Suspension]
Hotckis sway bars
Drm aluminum steering rack bushing
DRM spec Bilstein shocks
C4 ZR1 17x19.5, 17x11
NT555 G2 275/40/17F 315/35/17R
ARP wheel studs
Carbotech xp10, xp8 pads
Quantum spindle mounted Front brake cooling duct(3")
Lowered on stock bolts
Corner balanced w 170lbs driver & 1/4 tank of gas @ Westend.
[Interior]
Sparco Evo driver seat
Mti racing seat rail
Hardbar harness bar
Cam lock 6pt harness
Vette works harness bottom Anchor
Momo sprint 350mm wheel
Nrg hub & adapter
12" Kicker subwoofer
5ch kenwood amp
Kenwood single din head unit
Aluminum interior door sill C5Z
C6 shift ****
swede shift boot
Aftermarket aluminum pedals and foot rest
passenger side mounted fire extinguisher
[Exterior]
Fixed headlight
Aci rear spoiler
Front tow hook
Rear tow hitch receiver 1-1/4” (for towing tire trailer)
Trackspec Hood vents
Shorty Antenna
Clean title in hand, registered in CA till Sep 2020.
All service record in hand during my ownership, including new engine build receipt.
The car handles awesome, sounds very good.
asking $18,000 OBO
Text @ 818-3O7-3850 Andrew for more info!
149k on chassis
[Engine]
Lower pan gasket
New Flywheel bolts
New serpentine belt
Pro balancer
Coolant temp sensor
Knock sensor
New 160 thermostat
Exhaust studs
Exhaust nuts
Valve springs
Valve cover gasket
Fuel filter
Comp cam
Dewitt radiator
And many more...
[Suspension]
Hotckis sway bars
ARP wheel studs
[Interior]
Hardbar harness bar
Nrg hub & adapter
5ch kenwood amp
C6 shift ****
swede shift boot
[Exterior]
Fixed headlight
Aci rear spoiler
Front tow hook
Shorty Antenna
asking $18,000 OBO
CCase01 (05-11-2019)
Giving a bump...
Mark.
Mark.
