Tach Wire??
Old Feb 4, 2005 | 11:35 PM
Blown-Interceptor's Avatar
Blown-Interceptor
Default Tach Wire??
Trying to find the tach wire on a 98 C5. Anyone know which one?
Thanks,
Jason
Old Feb 5, 2005 | 02:37 AM
MelloYellow's Avatar
MelloYellow
It's a PCM Wire, Red connector, White wire.
Forget which white one, there are 2.
#7 maybe?
Old Feb 5, 2005 | 10:23 AM
Blown-Interceptor
Thanks...on my car, the white wire does not seem to be the tach wire. We are trying to install a window switch and it is not reading the tach rpm when we connect to the white wire.
Thanks,
Old Feb 5, 2005 | 03:42 PM
Drako's Avatar
Drako
This happened to me on my y2k vette. sometimes it's difficult to get that signal coming through clean when you tap into it. I can't really give any concrete advice except to say try tweaking the wire, wire tap a bit until you get a voltage reading on a multimeter.
it's a bit finicky just keep at it.
Old Feb 7, 2005 | 10:09 AM
kromberg's Avatar
kromberg
Search in the C5 tech section. I know that there have been a couple write ups there.
Keith
Old Feb 8, 2005 | 11:23 AM
juiced's Avatar
juiced
There's actually 4 white wires, 2 close together, 1 thicker Guage, 1 off on it's own. Use the one off on it's own.
Here is the Link to the Writeup.
Tach Wire
Old Feb 8, 2005 | 11:34 AM
slamar1's Avatar
slamar1
Tach Wire
Raptor install will guide you!
Old Feb 8, 2005 | 09:55 PM
MelloYellow
Don't forget you MUST run the MSD RPM switches in 4-Cylinder mode with our PCM.
That means cutting the 2 loops of wire coming out of the MSD box to break those loops.
To Tach Wire??
