turbos and cams?
Old Feb 15, 2005 | 08:52 AM
donnyonee's Avatar
donnyonee
Default turbos and cams?
whats a good performance cam for the c5 running stock compression? thanks, don
Old Feb 15, 2005 | 10:23 AM
Shinobi'sZ's Avatar
Shinobi'sZ
The 02 Z06 cam will work good with the stock C5 compression ratio. If you have a stock LS1 and don't intend on getting into the motor (heads, forged pistons, etc..), you could add a TT or S/C to it and 7-9lbs of boost max. You will have to upgrade your fuel components too.
Regardless you should upgrade your valve springs for a S/C or TT.
