racetronix users....
Old Feb 17, 2005 | 10:03 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Originally Posted by Busa196
Mine is at 60-61 at idle, then drops to 50-52 at WOT WTF? It basically does the exact same thing my stock pump did.
change your fuel filter. The filter contains the fuel pressure regulator. If you are losing pressure you may have a blockage. I gained 2 psi across the board. From what I am reading 54-56# is normal at WOT.
Old Feb 17, 2005 | 11:04 AM
Busa196's Avatar
Busa196
I changed the pump and the filter at the exact same time
Old Feb 17, 2005 | 11:42 AM
z06cab's Avatar
z06cab
What is the pressure of a stock system??
With a blower setup, what #'s would be needed?
Old Feb 17, 2005 | 02:47 PM
TANGLVR's Avatar
TANGLVR
Originally Posted by Racetronix
What voltage are you running under idle / normal driving conditions?
With a brand new optima yellow top with stock output alternator it's at 14.0-ish at idle no accessories or lights running.
Old Feb 17, 2005 | 03:32 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Pressure with the stock system is 58# at idle 54# @ WOT. You dont want your pressure going below 54 I dont think. With your blower set up fuel pressure will depend on injector size.
Old Feb 17, 2005 | 08:24 PM
z06cab's Avatar
z06cab
they're 42#injectors...some say get the pump some say not to..just trying to see what others are possibly running or not running...
Old Feb 17, 2005 | 08:29 PM
ICULUKN-C5's Avatar
ICULUKN-C5
The stock pump is pretty strong. I was able to have 36# injectors and spray a 180 shot. I dont think I would have pushed the stock pump any harder than that.
Old Feb 17, 2005 | 09:41 PM
RoadRebel's Avatar
RoadRebel
Ive run well over 500 to the tires with 42 lb/hr injectors on the stock pump many times.
Phil
Old Feb 18, 2005 | 12:40 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Phil
YA... but you're a freak... J/k...
My Head and Cam N2O car made 560 RWHP on the stock pump.
Old Feb 18, 2005 | 06:17 AM
big bollas's Avatar
big bollas
Default yo..
I would think that the first restriction would be the filter sock on the inside of the gas tank. Bad thing is the kit does not come with one !
When I helped "Busa" install his pump we wanted to change it out with a new one and GM's part department told us you would have to buy the whole fule pump assembly for $500.00 So with no choice we had to put the old one back in but I think that this should be included in the kit or at least offerd by the seller when you buy the pump.
If your car is newer with less miles dont change it, but if it has some miles on it I would say change it while you can "why do it twice".
I had my stock fuel pump all the way up until I made 575rwhp and then I added a "BAP" to it and now I am at 640rwhp with no fuel issues with a 150 TNT shot..
I may be wrong but I dont think that the demand on the fuel pump when you spray is as demanding as it is when you have a blower
Old Feb 18, 2005 | 08:13 AM
SmoothFRC's Avatar
SmoothFRC
I did a decent amount of research with this - LPE was able to sell them seperatly and they were only around $20 - So i purchased one for the next time i would have the pump out.
I recently ordered the fuel level sensor, and to my surprise - This came with a SOCK also...?? And to TOP it off - Racetronixs now sells them also, and when i recieved a replacement pump - sure enough, they sent me a sock with it.
So i went from having NONE, to 3
Old Feb 18, 2005 | 09:05 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Racetronix includes a new filter sock with their pump now . From what I am told, they have been including it for the past 3-4 months.
Old Feb 18, 2005 | 09:43 AM
  #33
Busa196's Avatar
Busa196
Go figure........
Old Feb 18, 2005 | 11:39 AM
  #34
Racetronix's Avatar
Racetronix
Supporting Vendor
Since the summer of 2004
Old Feb 18, 2005 | 02:01 PM
  #35
ICULUKN-C5's Avatar
ICULUKN-C5
just an update. I am seeing 62psi cold (first start of the day), 60 at idle (warm), and 56-58 at WOT. guess the pump just needed to loosen up a bit.
Old Feb 24, 2005 | 03:46 AM
  #36
Racetronix's Avatar
Racetronix
Supporting Vendor
Default C5 Return fuel system infomation
It has been brought to our attention that people converting their C5's to a FM FPR have been leaving out a few parts which are key to the proper operation of the system.
One key component that some people have been leaving out is the RR fuel feed hose with checkvalve. Seeing as a C5 does not have a checkvalve in the stem of the fuel pump it is imperative that this line is used in order to keep pressure in the system for startup purposes. Without this checkvalve the system pressure will bleed back to the tank when the car / pump is shut off. This can cause hard start / longer crank to run times.
GM P/N 10413424 Item 33 in > this PDF <
Old Feb 24, 2005 | 04:32 AM
  #37
MelloYellow's Avatar
MelloYellow
Great catch Jack!
Hasn't cause major issues for me yet, but will fix that ASAP.
Old Feb 24, 2005 | 09:27 AM
  #38
SmoothFRC's Avatar
SmoothFRC
I would be curious if the 99+ Systems also use the same item number and have the check valve their also...
Old Feb 24, 2005 | 02:31 PM
  #39
MelloYellow
Seems to be a '97-'98 only part.
List was $107...
