cam experts step inside.
Old Feb 17, 2005 | 02:46 AM
zelement's Avatar
zelement
Default cam experts step inside.
For those of you that are cam experts, how much overlap is too much? Is 14 degrees too much?
Also, Should a blower cam have more lift on the intake side or the exhaust side?
TIA,
Paul
Old Feb 17, 2005 | 09:42 AM
kromberg's Avatar
kromberg
Normally S/C cams have more exhaust duration and lift. This is because the S/C is forcing the air into the cylinders, so it is more important to have more exhaust duration and lift to help remove the combusted fuel/air. As far as how much overlap, it really depends on several factors: CID of motor, flow rate of the S/C, overall power goals, and so on.
Keith
Old Feb 17, 2005 | 05:28 PM
myblackC5's Avatar
myblackC5
Default overlap
TIA,
Paul
with 14 deg overlap, it will probably sound like a model a ford. i could be wrong but i think a stock cams have close to 50 deg. overlap.
Old Feb 18, 2005 | 12:55 AM
zelement's Avatar
zelement
Originally Posted by myblackC5
with 14 deg overlap, it will probably sound like a model a ford..
I'm not sure what you mean?
Old Feb 18, 2005 | 01:53 AM
Loboost's Avatar
Loboost
I think he meant 114 degrees.
Les
Old Feb 18, 2005 | 02:13 AM
zelement's Avatar
zelement
Les
is everyone on the same page here?
I am talking about overlap not lobe seperation.
From what I understand, the more overlap a cam has the more the lumpier the idle and less vaccum because all the air is getting blown out the exhaust. I seriously doubt a stock cam will have 50 degrees or 114 degrees of overlap.
All I am asking is what is an acceptable amount of overlap for a blown motor?
Old Feb 18, 2005 | 06:58 AM
7LitreC5's Avatar
7LitreC5
It depends. If the 14 degrees of overlap is at .050 it is a huge amount. If it is at advertiesd it is a tiny amount.
Old Feb 18, 2005 | 09:42 AM
budmont's Avatar
budmont
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
What he ment to say was:
The period when both valves are both a little bit open at the same time is called "overlap." Small overlap produces more torque at low engine speeds, but not so much at high speeds. Large overlap produces lower torque and low engine speeds, but more power as the engine runs faster.
As overlap is decreased, the engine loses the ability to run at high speed, but it might pull like a tractor at low speeds. Small overlap prevents exhaust from entering the intake manifold at slow speeds, but can't pull that extra intake charge at high speeds.
As overlap is increased, the engine produces more and more power at high speeds, but it has more and more trouble idling and running smoothly at low speeds. Large overlap can allow exhaust to be pushed backwards into the intake at slow speeds, but serves to charge the cylinders with more fresh air/fuel mixture at high speeds.
Old Feb 18, 2005 | 02:16 PM
3XBlack6spd's Avatar
3XBlack6spd
So, after reading Budmonts professional explaination, I might add, to answer you question, on a SC car, you want less overlap, otherwise you will bleed off boost. Good Luck....
And BTW this doesn't make me a cam expert, just my .02
Old Feb 18, 2005 | 03:00 PM
DDSLT5's Avatar
DDSLT5
Yes - less overlap, more duration on the exhaust - fine line.
Old Feb 18, 2005 | 03:15 PM
myblackC5's Avatar
myblackC5
Default overlap
you can go to vinci web site, he list the amount of overlap for each cam. a cam with 212 in, 218ex.....550in lift, 550ex lift, on 114 lobe centers has 52 deg of overlap. that would be at 50 thousands. i could be wrong on lift numbers, but that would make a good mild SC cam. also the stock LS6 cam works good.
Old Feb 18, 2005 | 04:11 PM
zelement's Avatar
zelement
Bud,
thanks for the explanation.
I know what overlap is and I know a lot of "overlap" is not recommended with FI cars. However, the question is, what should be a good amount of overlap for FI cars.
VortechC5,
Yes, I believe it is 14 degrees @ .050. Is that too much?
Do you know the amount of overlap on your cam?
Old Feb 18, 2005 | 05:15 PM
budmont's Avatar
budmont
[QUOTE=zelement]Bud,
Had no doubt that you knew, was just trying to explain why MYBLACKC5 said "it will probably sound like a model A Ford"
To cam experts step inside.
