MDMC fuel system photos
Former Vendor
Originally Posted by jdell
That's a pretty sweet looking system. When I get my 'vette, you'll be the first one I call!
For now, I am just wanting one...
JD
JD
310 is made by Bosch and pumps 310 LPH
Racetronix is 255 LPH and is made by Walbro.
I have heard that the longevity of the Bosch is superior, but I have not had any problems with my Racetronix yet. Other than that, I don't know if any differences. Anyone else want to chime in?
Originally Posted by opticZ06
Puttin her to the test this weekend at A&A Corvette.
Just for reference, when my car was @ Xtreme, the BAP was turned all the way to 0. That means no BAP. So with the LPE Fuel Pump and the MDMC fuel return system (retrofit) my fuel pressure went to 70pis and then dropped to 64psi over the last 2000 rpms.
For comparison purposes, when I had my TTi Stage III system I only had the LPE Pump (no BAP which is the same as the BAP turned off). I did not have the MDMC return system. My fuel pressure would go to 64psi and drop to 54psi over the last 2000 rpms. The addition of just the MDMC system (return, regulator, etc..) allowed for an additional 6psi in Fuel Pressure and held 64psi with no BAP.
This weekend at Andy's we will be running a 16-17lbs boost run...the BAP will be turned all the way up this time. So it will definetly put the LPE 255lph pump to its limits and will put the overall fuel system to the test. I will say now that I will consider it a success if 60psi or over can be maintained with max boost at max rpm.
Former Vendor
After we "waxed" our third 255 pump we went with the Bosch 310 we have had no problems from there on out. At this point with the in-tank Bosch 310 and the return system we have achieved 1012 RWHP with 15 psi and in two weeks we will go for broke.
Cheers
MDMC
OpticZ
Originally Posted by kumar75150
hmmmm if i decide to go turbo, looks like i know who to call about a fuel system
Very nice setup
This dyno graph was produced using the MDMC fuel system (Return & Regulator only..not the pump) and NO Boost Reference.
Not saying I don't like boost reference. I just don't have enough pump to support 1:1 boost reference. Asking the pump to pump more than it is designed makes the pump less efficient.
My FP was a solid 62psi at the rail from start to finish on this run.
I also just recently found out I had 3 broken spark plug wires during these tuning session. I am more suspicious that the broken spark plug wires were causing some misfires between 4000-6500rpms vs what I previously thought (spark plugs). But I won't be able to tell for sure if it was plugs or wires now because I have replaced both the plugs and the wires.
dads,
I believe I was the first person Sean let have pieces of the MDMC kit, parted out. I needed a return system and just happened to ask one day what he had going on with his cars, and he was kind enough to share. I asked him if he would be willing to sell his return setup, since he had already tested it out and it was successful..and to my surprise he said OK.
I think he was a little hesitant to keep doing it, because others purchased the pieces and then were calling not knowing how to install them. I think it was time consuming for him to be trying to walk DIYer through the install process. At some point in time I remember him wanting to only sell to shops or experienced DIYers.
I think he sold the pieces to me at a discounted price since I was trying it out on my TT. I don't know what he sells all the pieces for these days. I think it would be best just to give him a call and ask him. I know that it worked for me.
#35
Keith
#36
Supporting Vendor
Originally Posted by kromberg
How sells this Bosch 310 LPH pump and it is compatiable with the C5 sending unit? Can the just the pump be swapped out for a Racetronix pump?
Keith
Keith
#38
Originally Posted by Racetronix
The Bosch pump is not compatible with the factory jet pump system.
Keith
#39
Less fuel than stock
Below is an email I sent to Sean in May. The fuel system was installled as recommended. I changed over from a late model 2003 Z06 system to MDMC's recommended return System. I was running out of fuel at 630HP. With the new MDMC system and The Kenne Bell Bap it ran out 30HP sooner than stock pump did with the BAP. Attached is correspondence sent to Sean back in May. He never responded. If you look at the fuel flow of the Bosch Pump he suplied you will see that it is not an upgradeat all. It does not support horse power numbers much greater than 600HP with 60# injector on a supercharged engine . Beware!!!
(Hi Sean: I received in my 40 amp Kenne Bell boost-a-pump. I now realize, that when they specify 50% voltage increase, that refers to a car that is only putting out about 11.5 Volts. In other words the Kenne Bell boost-a-pump will only put out 17.5 volts max. Are you using a MSD controller that can put out 22 Volts? My experience here is that the Bosch Pump does not put out quite as high flow as did the stock pump did at the same 17.5 volts. I looked up a Bosch 0 580 254 979 pump and it is rated at 165 liters / hr @ 75 PSI. I am not being successful with this setup. What do you think I might be doing wrong?
Best Regards Glenn)
Best Regards Glenn)
