Cam?
Old Feb 24, 2005 | 12:23 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Default Cam?
Say I was hypothetically having a TT kit made for my car in 3 weeks. I've got a 232/236, on i 'believe' 112LSA cam, and have a feeling it wouldn't be safe for boost. What do i need to look for in a cam, oh, i'd be running ported and polished Lq9 heads, this car is driven daily, and noise and rumble may only be sacrificed for more/safer power.
Thanks,
Chris
Old Feb 24, 2005 | 10:47 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Thanks,
Chris
I would be more concerned with the lobe separation angle vs your duration...but then again it depends on the Turbo system (kit characteristics). General statements for FI cams are, 114-117lsa and moderate duration...assuming you have a 346cid too. The split durations on the cams used for FI are usually to optimize system performance. If you have a TT system that has a better intake than exhaust..then it is recommended to use a cam with less intake duration and more exhaust duration, this helps scavenge exhaust and avoid reversion. If the kit has good intake/exhaust than a single pattern works fine. I would stay away from a cam that has a lsa lower than 114...just my 2 cents. Call Cammotion and have them spec one for you.
Old Feb 24, 2005 | 11:40 AM
Stangkiller
Thanks for the reply, how do i get ahold of Cammotion? Also, is the higher the LSA going to equal more power? What is the different LSA's going to do for me?
Thanks very much,
Chris
Old Feb 24, 2005 | 12:20 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Thanks very much,
Chris
I am not some super knowledgable person when it comes to describing valve events associated with cams. JRod is a master on here when it comes to that..as well as few others. What I do know about them is that when I was using cams with a 112lsa on my NA motors..that the power curve was different. The 112lsa cams that I used 229/229 and 227/232 made more off the bottom and especially more power through the midrange...right where a NA LSx needs it the most. Overlap is the amount of time the intake and exhaust are open at the same time, on a boosted car you don't want this because there is a tendancy (depending on application) to blow boost out of the exhaust valve (bleed off boost). A larger LSA has less overlap, so there is less chance of boost bleeding off, or reversion back into the cylinder. Like I said there are some real Cam experts on here and over on LS1tech that can give you more information than you will ever need to know on cams. Do a search on LS1tech or this forum..or wait and maybe one of them will chime in.
Old Feb 24, 2005 | 02:31 PM
Stangkiller
Thank you very much! That's all the info i need, time to start cam shopping...Jrod or anybody else care to elaborate?
Thanks again!
Chris
Old Feb 26, 2005 | 10:44 PM
Stangkiller
Ok guys, last quesiton would my cam a 232,236 on a 112lsa work for at least a little while being magnacharged?
Thanks,
Chris
Old Feb 26, 2005 | 11:29 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Thanks,
Chris
It would work...however not as well as a cam designed to go with the Magnacharger. I believe the LPE GT3 cam is for the Magnacharger, I am not positive though. Check with ECS or one of the other Maggie installers (LPE, 20th Century). The Maggies only work to about 5-7lbs of boost, and seem to be more sensitive. I haven't seen one work on a big bore/stroker yet. They seem to work best with the right cam and headers.
To Cam?
