ATI Pulley Problem
Old Feb 28, 2005 | 08:17 PM
urslooow's Avatar
urslooow
Default ATI Pulley Problem
My oil changing "corvette Mechanic" noticed that the small little circular pully (not powering anything but just leans on the ati belt) on the upper right of the ati P-1sc setup was very uneven and oval and when the car was cold could easily be spun by hand (but not when hot). I took a couple of fotos to email to Breathless (ernie said that this ?idler should be leaning on the belt at all times and should be round). One of the fotos shows that one side is indented kind of like the shape of a wheel w/o the tire on it when viewed from the side. The car runs pretty good made at least 5psi the other day (ran out of room). Anybody had this problem? what could have caused this?
Old Feb 28, 2005 | 08:28 PM
BlackMagicC5's Avatar
BlackMagicC5
Can you post pictures?
Old Feb 28, 2005 | 08:31 PM
urslooow's Avatar
urslooow
Don't know how. It says on my screen that I "may not post attachments"
Old Feb 28, 2005 | 08:49 PM
urslooow's Avatar
urslooow
Hey Black MAgic I emailed you the fotos, thanks for attempting the posting
Old Feb 28, 2005 | 09:02 PM
blu00rdstr's Avatar
blu00rdstr
When was the last time you changed the bearings? The 'indent' can be caused by the pulley not spinning as fast as the belt, and the metal pulley wears away in the center. What can happen is the ball bearings seize up, and the pulley spins on the bolt.
Old Feb 28, 2005 | 09:09 PM
BlackMagicC5
Here you go.
Old Feb 28, 2005 | 10:13 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Nice polishing job... that is shot for sure.
May want to consider an upgrade to an A&A or ECS bracket while you have that all apart replacing that.
Looks like the bearing is eaten up and the pulley was not spinning at the same RPM as the belt.. it is suprising you did not hear that. Looks like it just slid on the belt until it clearanced itself.
Either way.. you are taking that puppy off!
Old Feb 28, 2005 | 10:27 PM
Busa196's Avatar
Busa196
Damn, that idler is toast. Get it over with and go with the ECS or A&A bracket.....I put it off a year and am sorry that I did.
Old Feb 28, 2005 | 10:29 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Bracket
You need to call A&A or ECS for their brackets....................
Everyone that have used ATI brackets end up moving up
Old Feb 28, 2005 | 10:48 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Yep, Idler is toast!! Too bad Procharger sold us all such a POS BRACKET!!!
VR
Old Mar 1, 2005 | 03:07 AM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
That is ugly.
Old Mar 1, 2005 | 09:50 AM
MIKE-C5's Avatar
MIKE-C5
Default ECS and A&A Brackets
Here are the brackets from the 2 best companies out there........
The first two pictures are from A&A and then there is 2 links on ECS....Can go wrong with either
Old Mar 1, 2005 | 01:25 PM
urslooow's Avatar
urslooow
spoke with Chris at ECSC his bracket and Tensioner kit is $890!!! Chris told me that ati offers the part free of charge. according to ati you don't even have to take the blower off, "it's just a bolt on part" according to the ati tech help line. Is this true guys? I don't have much if any experience working on cars, I used to change my oil, and I chg tires would it be possible for me to do this idler swap myself? Ernie at Breathless hasn't had time to even look at my email, he's trying to look around his shop this afternoon to see if he has the part (I'm curious to see if he charges me for this free part). Ernie also said that he hasn't had "hardly any" of these idler pulley problems come back. Bearings on the blower were changed about 1 yr ago.
Do any of you guys get tired of repeatedly having these cars fixed and re-tuned. It seems like I'm always having to tweak the car in some way, new radiator (+laydown), injector failures, I don't know sometimes, I guess when I'm driving on the track it all makes up for the time and effort I put in!
Old Mar 1, 2005 | 08:20 PM
vetterdstr's Avatar
vetterdstr
You can replace this idler... then 3,000 miles (or less) you will be doing it again... Pay me now, or pay me later...
VR
Old Mar 2, 2005 | 07:09 PM
urslooow's Avatar
urslooow
maybe I'm lucky but this original idler lasted 24,000 miles and 3 yrs! I may sell this car in the fall when I get the C6 z06. But I'll keep an eye on it. I really needed a quick fix since I'm running at the NASA Moroso road course this weekend. Thanks for the heads up. I'm having my regular vette mechanic do it, I assume that you have to take the tension off the tensioner and then just bolt in the part
Old Mar 3, 2005 | 10:19 AM
FRC Tom's Avatar
FRC Tom
2) 9/16" wrenches, loosen the bolt, slide it out, slip in pulley with spacer, slide bolt in, and tighten.
Old Mar 3, 2005 | 11:39 AM
urslooow's Avatar
urslooow
AFter calling ati i asked for the idler pulley and I described the part to the tech, I don't know if he sent the right part (Andy at A&A said to get the 3" pulley but I didn't ask ati for it) It looks like they sent the 3" part is this the correct part? it is the same thickness (1 1/8") just larger in diameter. can anyone get this new foto on for me, the new part is black, old was polished
To ATI Pulley Problem
Old Mar 3, 2005 | 04:17 PM
BlackMagicC5
AFter calling ati i asked for the idler pulley and I described the part to the tech, I don't know if he sent the right part (Andy at A&A said to get the 3" pulley but I didn't ask ati for it) It looks like they sent the 3" part is this the correct part? it is the same thickness (1 1/8") just wider. can anyone get trhis new foto on for me, the new part is black old was polished
Here you are:
Old Mar 3, 2005 | 04:39 PM
urslooow's Avatar
urslooow
I drove to my mechanic and had him watch me put in the new pulley, this was the correct part (I understand that the black color comes off pretty fast), started her up and the pulley made contact and spun well
By the way the bearings on the old misshapen pulley were ok, once it was off the bracket it spun very easily, so what exactly is the mechanical problem with this distorted idler?
Thanks a bunch to you guys for the quick responses and esp John G for helping post the fotos!
Old Mar 3, 2005 | 04:59 PM
BlackMagicC5
No problem. Anytime. Hope you get it all sorted out.
