mag sc question
Old Mar 8, 2005 | 12:55 PM
Allan Wagner's Avatar
Allan Wagner
Default magnacharger question
Do you need a special tune 4 this setup or does the chip that it comes with good enough my car 4 now is pretty much stock and if i add a blower cam how much more hp could i get.One more thing i have borla stinger exhaust and i want 2 order the lg long tube headers with cats but im not sure how loud its going 2 be in the inside of the car because its pretty loud now any of you guys running this exhaust setup?
Old Mar 8, 2005 | 01:33 PM
c5_from_jc's Avatar
c5_from_jc
Special tune will be neded.
Old Mar 8, 2005 | 05:13 PM
ScottN's Avatar
ScottN
St. Jude Donor '05
I will most likely add a Mag in the next year or so. From what I've read, you should get a custom tune if you have any other mods that go beyond basic mods like an intake and/or catback exhaust. With a cam upgrade and the headers you should get the custom tune.
I can't answer your question on how much HP the blower cam will add. I would guess 20 - 30 HP. Hopefully, someone else with more cam/FI experience will jump in and give you a better answer.
Old Mar 8, 2005 | 05:50 PM
SteveL2's Avatar
SteveL2
There has been one member (can't recall whom) that was able to run successfully with the tune that came with it; however, that as reported has been the BIG exception, as most folks have needed a custom tune.
My blower cam from 21st Century Muscle Cars provided about 40 rwhp, and much of that horsepower came at the higher end of rpms where the Maggie was running out of steam on its own. If you use one, you also should upgrade your springs.
Old Mar 8, 2005 | 10:56 PM
Devils Elbow's Avatar
Devils Elbow
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Do you need a special tune 4 this setup or does the chip that it comes with good enough my car 4 now is pretty much stock and if i add a blower cam how much more hp could i get. Get a pro to tune it, LPE, ECS, A&A, etc. check other threads. My mn6 w/ headers does 465rwhp/456 lbft. Others with blower cams are pulling over 500. One more thing i have borla stinger exhaust and i want 2 order the lg long tube headers with cats but im not sure how loud its going 2 be in the inside of the car because its pretty loud now any of you guys running this exhaust setup?I am not running Stingers but the headers and hi flow cats will increase the loudness a lot - I switched to a quieter cat back system after adding headers to tone it down and get rid of bad reasonance.
Hope this helps.
To mag sc question
