Is there any way to access a nitrous line through the drivers side firewall/footwell, or will I have to drill? -- Is there even a place to drill a hole in that area? I've read there is a large grommet in back of the battery which is on the passenger footwell which apparently you can snake lines through, but for my application I need to access into the drivers side. I would very much appreciate your help.
I was able to get to this area really easily by taking off the driver side wheel, and the plastic panel in the wheel well. Theres little bolts down the side and under the car. The plastic peice comes right off and you have good access to that area.
