Which magnason?
Guys
here's my reasoning....small coolant reservoir...
small heat exchanger...
small intercooler...
intercooler in the middle of airflow path causing airflow restriction thereby lowering intake cfm's, boost, and power levels and acts as a heatsink as it will warm up since it's right on top of the engine and below the intake
large cost compared to alky injection kit which will do better reducing temps and will give you more horsepower as well
do a search...there are extensive posts on the topic
I'd talk with a tuner or directly with Magnacharger....
I dont honestly understand your reasoning. If you are comparing an I/C Maggie to a Non I/C Maggie w/alky your comparing apples to oranges. 1) It is obvious that a non I/C maggie will make more power w/alky.
2) It's been proven that an I/C Maggie makes more power than Non I/C.
3) It's also been proven that an I/C Maggie w/Alky makes more power than a Non I/C Maggie w/alky.
Sometimes there is a necessity to have both. In my climate I need all the cooling I can get. The cooler the charge the less chance of detonation (But I know you already know that.)
The main thing that I see is, is the additional cost worth the additional protection and or power???
I do agree that the I/C Maggie is probably less efficient due to air flow restrictions. But that just proves that the cooler IAT's do a better job than the airflow.
But..... I could be way off. I could have just taken too many pain pills so I am only making sense to myself.
BTW, You should fly out here next weekend. The ECS boys will be out here trying to kill their livers...
Jeff
Jeff
Pain pills or not you're still making sense, but I've had a lot to drink so maybe we're on the same level. I agree with #2 above but only with 1 and 3 when comparing the Non I/c with the I/c with the stock pulleys they come with. Magnuson put a smaller pulley on the I/c version which is what I feel is making the additional power over the Non/ic. I do feel the lower IAT's play some of a part there but personally think it's minimal. I feel they did the smaller pulley to overcome the airflow restriction.
I'd like to see a straight up comparison using the Non IC 3.5" pulley on both or the 3.4" pulley fron the IC'd on both to see what's what. Problem is that so many setups differ even in small ways that it would be so tough to do. Anyone want to lend me their Intercooled version and I'll swap my 2.8 pulley on it and see if we can get a tuner to tune it for free in the name of Research and Development and the general good of the C5 Community?
Can you direct me to the setups you've seen that show the IC'd w/ alky is proving better? Seriously, all I've been able to uncover is the opposite and I've been looking hard for a while. I believe intercooling is the way to go and alky on top is just gravy but with the size and placement of Mag unit I haven't been able to justify doing both.
But for you, with 120 degree desert heat, hell yes you need all the temp reduction you can get....but it will be great to have those IAT's low and be able to pound on it whenever you like.
I'll make it out there sooner or later....my girl and I actually thinking about having our respective bachelor/ette parties out there in September.
THAT is EXACTLY what DOUG at ECS just posted in a recent thread here and i confirmed another top opinon of a well known tuner who also agrees with the above proposition!!!
All in all the non-ic with AI can make about 30 hp more than the i/c with AI (1psi~30hp on the LS1) but this is not worth it to me considering the area where I live.
Now the KB will be a whole new ballgame, I hope to heck that they put a I/C on that one so that we can turn it up to 15 psi.
If you really want more hp add a 100 shot in front of the magie lol
More Than Zero
ps IMO the i/c maggie is right in a sweet spot for the c5 after about 500rwhp a lot of things start to go wrong, and I see a lot of people with acam and max bolt-on's getting to the 500~530rwhp range with the I/C maggie with out a lot of BS to deal with.
BTW - FI is all about providing more HP gain than the losses of that particular system (backpressure for Turbos, parasitic losses for SCs, air restrictions for I/Cs) so if the intercooler provides some air restriction, yet ultimately makes more HP, it's up to you if you care or not. To me, it's doing it's job. If you're after ultimate HP, the Maggie shouldn't be your first choice, anyway.
