Plxdevices.com
Old Apr 6, 2005 | 05:32 PM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Default Plxdevices.com
You might want to check out their website for inexpensive wide band meters and controllers. The M300 has a digital display with two outputs: one wideband analog and one narrowband output that you can plug into the GM PCM O2 connector; allowing you to simply replace the existing GM O2 sensor with the wideband yet still keep the vehicle computer happy. The M300 is no bigger than a pack of cigarettes.
Regards Greg
Old Apr 6, 2005 | 05:38 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Regards Greg
How much is this product?
I dont need a gauge, I will be handling display through my Blitz SBC boost controller
Old Apr 6, 2005 | 06:02 PM
Robiwan's Avatar
Robiwan
Blowerworks,
Have you used the NB output from the PLX controller in place of the stock NB02 sensor for input to the PCM? Does it work OK? I have been trying to find the voltage vs AFR for the stock NB02 sensor, to see if it matches the bosch WB02 with the PLX controller.
Robi
Old Apr 6, 2005 | 06:14 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Here's another wideband that's a very resonable price. I've installed a ton of them.
http://www.techedge.com.au/vehicle/wbo2/default.htm
Old Apr 6, 2005 | 07:55 PM
BlowerWorks
Supporting Vendor
M300 With Display & Bosch Wideband $329. M250 (less Display) $299. Yes I Have And It Does Work For Feeding Narrowband Signal Back Into Gm Pcm. I Supply A Quick Connect Cable With O2 Connector For Plug-n-play. Regards Greg
Old Apr 6, 2005 | 09:07 PM
AVB's Avatar
AVB
http://www.innovatemotorsports.com/x...cat=252&page=1
LM1 w/o the box..
BTW, 340ish at Summitt
Old Apr 6, 2005 | 09:29 PM
ICULUKN-C5's Avatar
ICULUKN-C5
The innovative LC1 is 199. Too bad they are backordered for 2 weeks.
Old Apr 6, 2005 | 11:12 PM
FreddyG's Avatar
FreddyG
Can you Please tell me where you can get these for $199? I'd be all over that!
Old Apr 8, 2005 | 04:50 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I have the PLX M300 and love it. I have the extra box that turned my old Air Fuel gauge into a wide band gauge as well. Added some velcro to my roof liner and the controller sits right behind the visor. Nice peice, good and small.
I, however, just had an O2 bung installed just for the Wideband O2 instead of trying to have the computer read the output from the device.
Their website is www.plxdevices.com
To Plxdevices.com
