nitrous mounting
Apr 17, 2005 | 02:32 AM
nitrous mounting
i have a nx wet kit on the way, and i was trying to figure out where to mount the solinoids for a clean look. if i could get some pics of your set ups that would be great.
Apr 17, 2005 | 09:41 AM
Cruise-In III Veteran
St. Jude Contributor '04
I mounted mine right on the radiator shroud. Pretty easy to mount them, plus they are away from the heat of the engine.
One before blower:
Eric
Apr 17, 2005 | 09:45 AM
Heres mine.
Apr 17, 2005 | 11:07 AM
thanks, that gives me some sort of idea.
Apr 17, 2005 | 08:30 PM
Mine looks like this:
Apr 17, 2005 | 10:58 PM
if you really have n2o on there, then you did a good job of hiding it
Apr 18, 2005 | 12:31 AM
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Quote:
Whatcha got? Where is it???
Apr 18, 2005 | 12:43 AM
Quote:
Look between the radiator hose and the radiator. There is a solenoid.
Apr 18, 2005 | 01:59 AM
That is one stealthy install, no ricer could possibly spot that.
Apr 18, 2005 | 05:50 PM
It's really all in plain view, I just gave everything an OEM appearance by using factory loom and flat black paint on the solenoids which (as already pointed out) are mounted to the radiator shroud. The nitrous and purge solenoids are on the right and the fuel solenoid is on the left.
Funny thing is that when everybody looks under the hood nothing stands out so the assumption is "just another stock LS-6."
Here are pics of my switches and how/where I mounted the purge lines (one per side).
Apr 18, 2005 | 07:31 PM
Apr 18, 2005 | 10:02 PM
that's very clever. it would have taken me a while to spot that solenoid
Apr 19, 2005 | 11:47 AM
Apr 20, 2005 | 10:20 PM
This is mine!\
Apr 20, 2005 | 10:22 PM
Heres mine
solenoids are mounted nicely in the rails... Thanks NX..
Apr 21, 2005 | 10:27 PM
From: ********************* Florida's Space Coast *********************
Here you go....
