HP Twin Kit
Old Apr 21, 2005 | 07:58 PM
MissZ06's Avatar
MissZ06
Default HP Twin Kit
I am getting a HP twin turbo kit in may (shipping it to them for install), it will have an electronic boost controller set from 6-9.5#'s boost.
1) Will the stock bottom take 9.5 if i run 104 octane
2) Do i need an alky kit at that level
3) If i did a rebuild and dropped to 8:1 how high boost level could i run?
Thanks for any help and I will keep you all updated
Old Apr 21, 2005 | 08:07 PM
mdhmi's Avatar
mdhmi
1. Yes, with a good tune.
2. No. Totally depends on tune and amount of boost.
3. You don't need to drop the CR that low. 9:5.1 is fine. The amount of boost you run has much to do with the turbo kit itself. There are guys that run 25+ pounds of boost on a 346.. All depends on specifics.
Mark
Old Apr 21, 2005 | 08:48 PM
flynbludream's Avatar
flynbludream
You might want to get a completion time guarantee IN WRITING.
Old Apr 21, 2005 | 08:57 PM
Bill Reid's Avatar
Bill Reid
1) Really depends on how you plan on driving the car, whether or not you consider it a daily driver, and what your expectations for longevity/reliability are. 9.5psi is running on the hairy edge for the stock hypereutectuc pistons ESPECIALLY on a turbo application. I assume this is on a Z06... with its higher compression ratio the gun is already half cocked. Ya, some get away with... but I know of some that didn't last.
2) I'd let the tuner tell you if you need alcohol injection. If your power expectations have been realized by a tune only (dyno and drivability), I assume with running 104 Octane 100% of the time, you would not need it.
3) IMO, Typically 8.5-8.75:1 (nothing higher than 9:1) CR coupled with a good turbo grind cam you could see 10-13 pounds of boost on 91 Octane. If you want to stick with 104 Octane, then obviously you could turn up the wic and spool 14-17 psi quite comfortably... this assuming the turbo's are correctly matched to the application.
Looking forward to seeing your results.
Best of Luck
Bill
Old Apr 22, 2005 | 08:05 AM
MissZ06's Avatar
MissZ06
Yessir, thats why I am shipping it to them. The have me scheduled for the end of may. It is not a daily driver, i put about 5k miles a year on it. I will be running race gas 100% of the time. My daily driver is a Subaru WRX (ok let me have it LOL). I will mostly run my vette at the 6 pound setting but eventually plan on getting the bottom end built.
Old Apr 22, 2005 | 09:51 AM
mdhmi's Avatar
mdhmi
No need to run race fuel on only six pounds of boost.
Mark
Old Apr 22, 2005 | 10:52 AM
AMGPilot's Avatar
AMGPilot
Hmmm.. I didn't know that Hewlett Packard made a twin turbo kit
Old Apr 22, 2005 | 02:33 PM
MissZ06's Avatar
MissZ06
Mark, i was talkin about the race gas on 9.5 boost. still no need?
Old Apr 22, 2005 | 02:47 PM
mdhmi's Avatar
mdhmi
Depends on the tune. Most of the turbo guys I know run a combination of h20 IC, meth, n20, Torco, or race fuel (mix) for added safety.
Mark
Old Apr 23, 2005 | 02:41 AM
hpcubed's Avatar
hpcubed
109 motorsport has something good in it.
To HP Twin Kit
